kby88;769755 said:I found out that my spark plug cover(tube) was leaking badly. So decided to change it.
Done top overhaul. All seal most of the worn out seal replaced including the valve seal. Cost me rm1450 and i'm happy with it now....
My car running wth the N42 engine..
SBB;769833 said:Hi kby88,
Mind telling where u did top overhaul, please.....mine same N42 wild mild white smoke but if I ram it, people notice who followed me.....aduiiiii
Vincent Hor;769887 said:I don't understand why mechanics are eagerly suggesting top or full overhaul for these N42/N46 engines. Good money and the perception that the engine is problematic?
Don't let them take you for a ride. White smokes & engine oil consumption could just be caused by harden valve seals. My mechanic don't encourage top or full overhaul on these Alu engines. Cylinder block needs to be rethreaded & new head bolts installed inorder to get back to factory torque settings. Thus cost escalates.
With the right tools & experience replacement of valves seals can be done without removing the head. I understand that this job can be done in under RM1k (parts & labour)
So before you jump straight to top/full overhaul, it's best to check with a few reputable mechanics for their views & options.
anaksarawak;769888 said:Well said Vincent!
Vincent Hor;769891 said:Bro, just realised that you have changed your nick. Enjoying you cabrio?
kby88;769928 said:Honestly, i'm still confuse with the term of "Top Overhaul".
However, most were referring replacing the valve seal and all other oil seal (top part of the engine) as "Top Overhaul".
Ya, mine they change the valve seal without removing the cylinder head.
