Matching sport springs to Koni abs ??
rbojs123022
Dearest Members and Forumers,:wink: Mine 328i E36 , currently using Koni abs soft/hard adjustable and bilstein sport spring.Tend to change the springs set, which d best ? H&R, Eibach or something else ? My Koni abs tuned to hard position but still feels soft, suspected the springs ? damper and bushing attachment changed already. Pls, anybody with good advise ? Thank U. :top:
Dear tchdaniel,
Thank u, bit my abs still new. probably i'm wrong, but could be the springs. any suggestion ?
Bilstein sport springs r the best,what Koni r u using,RED or Yellow sport?Who did the installation?Did u use the air tools,if Yes....sayunara
Bro,
my previous set up was yellow koni adjust sft/hard + eibach spring. It seems that eibach failed me recently (Too soft) and wrecked my damper.
Now my new setting with bilstein spring, (Cannot find H&R spring for my 6potters)Results:Superb (So far so good).
Having said that,I suspect that ur koni had issues.i dun even have to set mine the hardest.. it is still firm.
i suggest,double check/ask second opinion on ur abs...just my 2 cents.
as for me Bilstein is the best or H&R,Bad experience wit Eibach back in 1992 on my E30,back then very hard to find Bilstein,nobody carries them so bought from Rennie Khoo...1st set,look like a dragster,front keep bottoming over small bumps wit a loud thump sound,at first i thought they gave me the 4 potter springs but he insist the part no is correct mean for 6 potter,2nd set,front too high,finally 3rd set got it level.you guys go figure.....
