E
elwine30
Guest
guys,any tips to do upgrade when overhaul M40 engine.1) port & polish2) 3 angle vavle3) balancing4) m43 lifters........ If i do all the above, what would my new engine be ??? :blush:
Originally posted by elwine30@Jun 17 2005, 09:27 AM
guys,
1) port & polish
2) 3 angle vavle
3) balancing
4) m43 lifters
Oooiii!Originally posted by elwine30@Jun 17 2005, 09:27 AM
guys,
1) port & polish
2) 3 angle vavle
3) balancing
4) m43 lifters
elwine how much would you think to overhaul the m40? just check out before you start.Originally posted by elwine30@Jun 18 2005, 10:59 PM
ok guys, please see other thread about cooling system. Learn a lot about it.
Anyway, I had a heart attack when my car was reacting badly past few days.
So, i jump into conclusion that my car needs a overhaul because of
1) burn valve
2) burn head gasket
So, it's time to for overhaul.
But findings today has lead that I have TWO problems.
1) cooling system
2) plug cables (number 2 was faulty)
elwine.....my advice is to stick to the original Bosch plugs. the iridiums are just a waste of money and their electrods won't last long.Originally posted by elwine30@Jun 19 2005, 10:17 PM
update today, change the plugs to normal ones from iridium. Appearently, my plugs all koyak. Sigh. , will post pictures up from my mobile later.
So, plug in the normal ones. The engine idling still bad. So, next course of action is to test the plug cables. Thanks kev. Should be number 2 is the culprit.
touch wood bro!!!!!Originally posted by nelsone30@Jun 19 2005, 01:04 PM
oioioiyyooroor
again brother....
why this month so many m40b18 all koyak lerrr
bad month for m40 arerrrr
