stormhunt3r;326598 said:
teejay, thx for the info. I didn't know oil would remains at the top cylinder head. my car had been through a top overhaul only. The engine still sounds good, juz a little tappety.
i'll search through the web for that.
you mentioned tappety? another possible oil loss is due to tappet adjustment that actually releases some oil into the combustion chamber, dont know to explain it further, perhaps Mechanical Engineer Sifu Mr Jules is able to expalin it in layman terms :top:
when you start the car in the mornings, thicker oil stays on the top cylinder head and is release , thats why first combustion you see smoke.
A simple test is to take a clean good morning towel wrap your exhaust start the car, then take the towel and soak it in a small pail of hot water.
take that water, then put it in the freezer, but if you have some chemical solutions , you are able to detect the amount of oil in the water.
After frozen if you can see droplets of oil, you would have some oil going into your combustion chamber for sure. Mind you there are some remnents of the oil in the towel,but you could further do an ash test, but this will require a full lab setup.
From there the volume of oil will be able to calculated how much oil is being consumed by the engine, compared with the theoretical value, the excess oil will indicate a leak in the combustion. Sounds alittle bit complicated ya!
