Help on M20 2.5 Upgrade
Frankie
HI GuysI think yours expert enought with M20 Engine. Need yours advise on the M20 2.0(M) upgrade to M20 2.5(M). Below is the item that i have at the moment :-1) M20 2.5 ECU2) Engine Blok without Cyclinder head.3) Air flow meter.4) 2.5 full Ekzos system.I am thinking to look for Cyclinder head and cam which is very costly full M20 2.5. Since i didnt have Cyclinder head. can i do like below:1) fixing the all item and use 2.0 celinder head.or 2) fixed item 2). only, other use 2.0or 3) other option (your suggestion).Please help.
Ya you can use the M20 2.0 head on the 2.5 block bro.There should not be any problem only less power sikit bro.
Click my name and search for the stuff I'm selling...you want short blocK? I sell cheap cheap.Performance parts...aha..that wan a bit on the high side.
hi guy
it is possible for e30 320i direct swap with e34 525i engine without changing the existing e30 manual gearbox,wire harness and ecu?
thanks
banliang8;440031 said:
hi guy
thanks
Of course it is possible, u can keep the same tranny but u have to customize the wire harness since e30 has C101 connector
frankie;416511 said:
hi guys
i think yours expert enought with m20 engine. Need yours advise on the m20 2.0(m) upgrade to m20 2.5(m). Below is the item that i have at the moment :-
1) m20 2.5 ecu
2) engine blok without cyclinder head.
3) air flow meter.
4) 2.5 full ekzos system.
I am thinking to look for cyclinder head and cam which is very costly full m20 2.5. Since i didnt have cyclinder head. Can i do like below:
Or
2) fixed item 2). Only, other use 2.0
or
Please help.
stroke it....................
