long shaft + coupling
kyree
Anyone here can recommend a place to check my E28 longshaft and couplingGot very loud sound
Got very loud sound
I changed mine few months back. Changed new center bearing with rubber mounts, and 2 couplings (front and back) @ Naidu's. Called Suan Huat to buy parts and they delivered to Naidu. He sent to machine shop to fit the new coupling and center bearing with rubber mounting and rebalance the long shaft.
Runs very well now, last time like machine gun.
ckchaw : can i know how much it cost? and where is Naidu's place?
Naidu's place is opposite KWSP PJ, on top of the hill of the shell stations. Search "shell Jalan 5/35" in google map.
if not mistaken, workmanship + balancing was RM120. Parts price i need to check my receipt, should be less than RM200. You can call up Suan Huat to ask, center bearing set and coupling front and back.
Job involves, removing exhaust, take out long shaft, repair coupling + install center bearing + balancing (at machine shop), reinstall. Good to change your differential bush at the same time while at it if it hasn't been changed. Mine was shot so i changed it together.
