climenta-325i;260608 said:
Hi all, my drive too giving me problems with the long shaft. Mine's a E36 325i, so sorry if I'm imposing. When I tested the car, it didn't take too much of my attention but the shudder was clearly distinct during acceleration from standstill and when you floor it. I got it checked, the foreman told me it's my drive shaft coupling and pointed at the joint-like thingy at the end of the shaft. He also told me that I can't change just the coupling, need to change the whole long shaft. Appreciate if you guys could enlighten me on these:
1. Can I change just the coupling and what effect would it give?
2. Are the long shafts for all E36 the same or similar?
3. How much for a good conditioned long shaft? How to determine a good one using just the naked eye? (sorry, I have to ask)
4. Is it better to buy and change in the same shop or buy at chop-shop and change somewhere else? Is it cheaper this way?
5. How much will the workmanship come to for changing the long shaft?
Thanks in advance, if got more advice can also p.m. me. Appreciated.
Don't waste your time changing the U-Joints (coupling) if your longshaft (prop shaft) is already imbalanced. I have tried that route it's wasting money.
The best solution is to buy a new one but this is quite an expensive item.
The next best solution is to get your mechanic to find one from the chop shop. You will probably pay a little bit more then sourcing it yourself. Insist that the mechanic give you a warranty that the one sourced by him is good. There is a lot of work involved when replacing prop shafts as the exhaust system will also be removed. Therefore if the one sourced by the mechanic is not good, you can avoid paying double or triple workmanship.
I had mine (328i) GM gearbox, prop shaft replaced recently. Previously I had vibrations/noise from 100kmh right up to 180kmh. The prop shaft for this set up is almost impossible to find at the chop shop for reason that it's a local model with GM box whereas all the chop shop ones were with either ZF boxes or Jatco hence the difference in length. One chop shop had one and the asking price was RM1,400.00 which I think it's cut throat price. BTW on inspection, I found that the U-joint is a bit sticky too.
I believe that most prop shaft problems arise from the sticky U-joint at the rear diff end. It's located at a hot area directly infront of the rear diff and above the exhaust pipe. It's also not well proctected. Dirt and water get splashed there resulting in the grease drying up and causing the roller bearings inside the U-joint to seize.
BMW prop shaft U-joints are held on by some spot welding. If you chose to replace the U-joint, the welding process is too hot for the grease pack which eventually will dry up and kill the roller bearings. Hence this route does not bring satisfactory results.
Some other car makes have a grease nipple and you can repack the grease after the welding process. Such prop shaft can accomodate this replacement of U-joint and get satisfactory results.
What I did was I worked together with mech, removed the prop shaft, then measure the length of the rear end of the prop shaft. (There are two pieces joint together) The front end usually don't give you much problem because it is very much better protected. My search was only for the rear end prop shaft which I believe it's availble as all sedan E36 has the same chassis and therefore the same mounting point for the prop shaft centre bearing.
We went to the chop shop and look for E36 prop shaft rear end with the correct length measurements. There were many available. We choose the best which is one with a good rear end u-joint. Amount paid RM400.
Fixed it back and my problem resolved.
