Just gor my car, few problems here :)
metalbox
Good day everyonehope you are in great healthjust recently getting my 2001 325ineed your advice here1. aircond - no cold air on driver side, but okay on passenger side 2. airbag indicator sometime appear3. engine oil indicator sometime appearthanks in advance:26:
Read somewhere in the forum that the AC is due to old broken filter. Might need to change the filter.
My advice is to service once you get the car. Change the oil to 5w-40 fully synthetic and also change the gearbox oil and pan.
I have the same problem for the AC. Read that it due the heater control valve from other. will check it out this weekend.
metalbox;814564 said:
Good day everyone
thanks in advance
:26:
1. Common issue, aircond is low on gas. This is a sign of a leak .Refill and ask them to add tracer dye so the leak can be found. I had this problem but after refilling gas no leak noticeable. It is also good to change the A/C filter which is sometimes neglected.
2. Could be a faulty airbag sensor.
3. Check if your oil level is low. If not, it is usually a faulty oil level sensor. Had this problem and replacing the sensor fixed it.
Airbag light is normally caused by broken passenger seat sensor, cost to fix is around RM480 for part only via ebay, BA selling for RM850
images
The other two issues are addressed by other SIFU.
Take your car for a full service and check.
thank you very much!
i guess, i have to check/service complete AC system
oil level is okay, it must be the sensor
now i know
passenger seat has airbag sensor.. :D
oh, forgot another prob
i can hear 'knocking' sound whenever i accelerate or decelerate
the sound is from rear diff
any advice?
Your long shaft mounting or coupling or bearing need to be checked. :)
Take it to a good workshop for comprehensive check ya.
A lot of us use Jack of Gloria Motors deep behind Summit USJ in the industrial area.....016 660 3181
Good day everyone
thanks in advance
:26:
3. if the yellow indicator appear for a few second after u start the car, then your oil level sensor already kaput. easy to fix, can do it when u do oil service.
this is how it look.
http://www.bokchoys.com/differential/pictures/oil_level_sensor_diy.jpg
now i know
passenger seat has airbag sensor.. :26:
proton also have this kind of systems nowaday.. :D
This few thread may related to your cases :
1) http://www.bmwland.co.uk/forums//viewtopic.php?t=122600
2) http://www.bimmerforums.co.uk/forum/f91/information-faq-airbag-warning-light-due-faulty-occupancy-sensor-bypass-guide-e46-t36479/
3) http://forum.e46fanatics.com/showthread.php?t=685544
As your problem 3, as Helena320 mentioned if the yellow indicator appear for a few second then goes off after u start the car, then your oil level sensor already kaput. I am having this problem now and i am ignore it cause i know that my oil lever sensor was the culprit not the oil lever low.
now i know
any advice?
Check your rear diff mounts and subframe bushings, these are usually the culprit.
PM me if you need more info or need help getting the parts.
many thanks guys
just refilled gas this evening and aircond is now working as it should
will change the filter later, i bought it already :)
i will check on oil sensor and subframe bushings later
btw
any recommendation on manual gearbox oil?
metalbox;814742 said:
many thanks guys
btw
You must drain the oil before you can remove the oil level sensor as it is at the bottom of the pan.
I use Royal Purple Synchromax in my car. I have seen many recommendations for this oil on a few BMW forums.
Same problem with AC sometime back, driver side hot air.
pumped gas all good, But only for 2months plus.. There is a problem somewhere.
Jarance pls share if u find the culprit, just hope its not cooling coil.
Thanks
Thanks
Mostly likely due to the leakage at cooling coil. Tried checking the heater valve as well?
For the Aircond issue, you all might refer to our sifu B33mEr on his My humble E36 ...Thread pages 4 posting #34
Thanks Alex and Wingzee, will get it checked next week.
im praying its the heater valve, i cant deal wt removing dashboard etc, haha
regarding AC
can we disable/remove heater
does malaysian spec got heater function?
