haywire
Official Member
- Mar 15, 2009
- 4,189
- 63
I have found this entry on m3forums.net while digging around the internet to help a fellow forummer.Might be useful for Japanese spec car owners...to have their radio frequency fully working in Malaysia without the use of booster or adapter.Basically the aim of this is to change the 'AREA' from 'JAPAN' to either 'EUROPE' or 'OCEANIA' in the radio service mode. If you are able to change the area then your radio should work perfectly.Try this out and let me know if it'll work for you guys.[Note: Unfortunately won't work on all cars as I understand it]Long but it will helpSound System, Cruise, Alarms, MonitorsNovember 2004 Technical ServiceSUBJECTProcedures to Enter the Radio Service ModeMODELAll vehicles produced after 09/2001Refer to SI B65 05 99 for information on how to enter the Service Mode on vehicles built prior to 09/2001.PROCEDURESE39 (5 Series) without Navigation systemE46 (3 Series) without Navigation systemE53 (X5) without Navigation systemE83 (X3) without Navigation systemE85 (Z4) without Navigation systemC53/CD53 (with or without MID)1. Turn the radio on.2. Within 8 seconds, press and hold the "M" button for 8 seconds.3. Scroll through functions using the + and "-" keys or the "< >" buttons.4. Turn the radio off to leave the service mode.E39 (5 Series) with Navigation systemE46 (3 Series) with Navigation systemE53 (X5) with Navigation systemE38 (7 series) with Navigation systemBM53 with small screen Board Monitor1. Turn the radio on.2. Press and hold the "RDS" button for at least 8 seconds.3. Scroll through the functions using the "< >" buttons.4. Turn the radio off to leave the service mode.E39 (5 Series) with Navigation systemE46 (3 Series) with Navigation systemE53 (X5) with Navigation systemE38 (7 series) with Navigation systemBM53 with Widescreen Monitor PRIOR to 9/011. Turn the radio on.2. Within 8 seconds, press the "INFO" button.3. From the Info screen, select RDS (choose PTY on E38).4. Press and hold the BM control knob (right side knob) for at least 8 seconds.5. Scroll through functions using the station search buttons "< >".6. Turn the radio off to leave the service mode.E39 (5 Series) with Navigation systemE46 (3 Series) with Navigation systemE53 (X5) with Navigation systemBM53 with Widescreen Monitor AFTER 9/011. Turn the radio on.2. Immediately press and hold the "Select" button for at least 8 seconds. The screen will switch to Service Mode.3. The screen will now show the serial number of the radio.4. Use the "< >" buttons to select the desired service function.5. Selections for the desired service function can be made by using the radio station preset buttons # 1-6.6. Turn the radio off to leave the service mode.NOTE :When selecting the country AREA, push the station preset # 1 repeatedly until AREA USA is shown on the screen.When selecting the GAL level, use station presets # 1-6 to select level.To turn off/on the RDS function on this radio, push the "INFO" button and select RDS off/on.E52 (Z8) with Navigation system C53 MIR radioNOTE : After replacing the MIR on an E52, the replacement radio does not require coding. When the radio is first switched on, it automatically enters an initial Service Mode ("No Area" is displayed). Repeatedly press the "1" button until US Area is reached and turn the radio off. The normal Service mode can't be entered until this is performed.1. To access service mode normally first turn the radio on.2. Turn the radio off.3. Turn the radio on.4. Press and hold the "SEL" key for 8 seconds until the service mode is entered.5. Use the "< >" buttons to scroll until you see area.6. Use the preset buttons # 1-6 to change the area.7. Turn off the radio to end the service mode.E83 (X3) with Navigation systemE85 (Z4) with Navigation systemCID radio1. Turn the radio on.2. Press the "SEL" button immediately and hold for at least 8 seconds.3. Scroll through functions using the "+" and "-" keys or the station search buttons "< >".4. Switch off the radio to exit the service mode. E65 (7 series) with Navigation systemMOST bus radio1. The iDrive controller is used to access the service mode.2. RDS on/off is accessed via this menu.3. From the main menu display, press the controller down for minimum 6 seconds.4. Turn the controller 3 increments clockwise (to the right).5. Turn the controller 3 increments counter-clockwise (to the left).6. Turn controller 1 increment clockwise (right).7. Turn controller 1 increment counter-clockwise (left).8. Turn controller 1 increment clockwise (right).9. Push down on the controller.10. To exit the service mode, select the return arrow at the bottom on the left of the screen.SERVICE MODE FUNCTIONSNOTE :Functions vary between models.Serial Number: Displays the radio serial number.Software Version: Displays the radio software version (Calendar week/Year/Version). GAL: Speed sensitive volume control.The speed sensitive volume control can be adjusted from level 1-6 using the 6 preset audio buttons. Radio volume increases more at level 6 and less at level 1 (road speed dependent).Vehicles equipped with DSP do not use this feature.Field Strength & Quality (F/Q): The station currently displayed can be assessed for field strength and quality.An "F" number (i.e. 1-15) is used to indicate the strength of the signal being received by the radio. A high "F" number indicates a strong signal.A "Q" number (i.e. 1-15) is used to determine the quality of the radio station broadcast including both the audio and RDS signal if applicable.DSP: Digital Sound ProcessorThis function provides information about whether or not the vehicle is fitted with DSP. (1=Yes, 0=NO)TP Volume: Traffic PatrolProvides adjustment for traffic report minimum value. On some vehicles this setting can affect the NAV volume.Refer to Service Bulletin B84 02 03.AF: Alternative frequency tracking setting. Not used in US.Area: Used to select the appropriate market setting (USA, Canada, Europe, Japan or Oceania). [This is what we are aiming to change]Index: Displays the revision index.
