I have a problem with buying a years 2008 e90 japan spec 325i
winsonchew
It's an E90 (Hi-Line) unreg unit years 2008 that import from Japan. I'm satisfy with the pricing.. Since the 325i is better than 320i and 323iBut I want to know Japan spec got speed cut?? Can unlock the speed cut if its lock??The 325i I'm purchasing is come with I-drive and full leather seat.. I'm satisfy with it..But the dashboard is in walnut color, not so like, but still can accept.The I-drive showing that the fm radio is only from 76 to 90mhz, omg, can't listen local fm radio. How to fix it huh??There are no reverse parking sensor in front & rear!! How come huh?? Japan spec no need using the parking sensor huh??How to change the GPS from Japan map to Malaysia map??Thanks sifu that can help me solve the above matter.
Reger to my answers below in bold.
No speed cut at 180km/h
Can contact our vendor, BimmerCoder, he can do the conversion
jap specs don't have park distance sensor. You can also contact BimmerCoder to put cameras or add third party sensors. Ori sensors also possible but pricey. A lot of work. Bumper, wiring harness, sensor brackets, park distance controller...
Not possible. Jap gps is a different system than malaysia's
Woahhh, it's seem like a lot of thing to do with Japan spec e90 huh??
Anyway, what is the advantage of getting a Japan spec e90??
If 325i only can run for 180km/h seem like not syiok!! Can unlock the speed cut by re-map?? Is it costly??
The fm radio can fix it then it's ok.
The parking sensor is a bit trouble now..
The GPS matter I think is about a DVD software?? If I change a Malaysia map software is it possible?
