Make my self a power bleeder using hose garden spray bottle. Brake fluid bleeding is so darn easy!!!! Trust me.. i even change the front brake hose while changing the fluid and no air introduce in the system. To make ur self the power bleeder pls refer to various diy site. i may post the pic of my bottle later on. tips: i dont use any pressure gauge to measure the presure, but i presurised the bottle just enough to force the fluid out from the nipple. and ohh.. those garden spray bottle normally can hold pressure needed to bleed the fluid (15-20psi) once it almost empty. u must hv atleast >0.25L fluid to maintain the pressure. and 1L is enough to change whole 4 tires + 2 front brake hose change.
