pussy & kinaka,Originally posted by pussy@Aug 21 2005, 09:27 PM
cklim.. why overhaul? upgrade... why cost of building/overhauling the engine would be the same of upgrading the engine..
check with a few forumers.. a M20 engine would be better !!
somemore, someone is selling his M20B27 engine also !!
Originally posted by cklim+Aug 22 2005, 10:18 AM-->QUOTE (cklim @ Aug 22 2005, 10:18 AM)
tak boleh... too much stress... :blink:Originally posted by Strider@Aug 23 2005, 09:04 AM
Waaa Pussy, you tak tido ka?
Originally posted by pussy+Aug 23 2005, 10:56 AM-->QUOTE (pussy @ Aug 23 2005, 10:56 AM)
Originally posted by Strider+Aug 23 2005, 01:21 PM-->QUOTE (Strider @ Aug 23 2005, 01:21 PM)Originally posted by pussy@Aug 23 2005, 10:56 AM
around 2k.. well on the worst side.. skim the head, worn valve guides, new valves? other stuff, oil,cigaretes, tani..Originally posted by DingChavez@Aug 23 2005, 01:14 PM
2K for a top overhaul??? WOW :blink: My mech quoted me for a top overhaul for les than 1K including labour and parts :dunno:
kinaka,Originally posted by KiNaKa@Aug 23 2005, 11:42 PM
this is wat i've posted on the e30 maintenance...
1990 M20B25 Motronic
1) Top overhaul gasket kit - RM260
- Valve cover gasket
- Cylinder head gasket (if sold seperately RM150/pc)
- Camshaft seal & o-ring
- Thermostat O-ring
- Thermostat housing gasket
- Intake & Exhaust manifold gasket
- Exhaust manifol to downpipe gasket (triangle shape X 2)
- Breather pipe o-ring X 2 (top & bottom)
2) Engine core plug X 12 (Normal steel - RM54, Stainless steel - RM126)
3) Water pump - RM110
4) Tensioner bearing - RM55
5) Timing belt ( brand : Continental ) - RM55
6) Engine Oil filter - RM15
7) Propeller shaft center bearing - RM95
8) M20B20 exhaust manifold to downpipe gasket - RM16
9) Roof chrome lining clip - RM26/pc
10) Ate Front Brake pad - RM120/ set
Hope this help.... thanks
opps.. he had too many items in one question..Originally posted by Zoggee@Aug 25 2005, 12:11 AM
this thread is misleading la...#sigh#![]()
Pussy... B) dun scare newbie like this...please...!!!![]()
the manual tranny from a Ljet can be use on a motronic engine la.
the only thing that cant be use is the Air Slide Valve.
And yes...the alternator from an early model Ljet syst. in Malaysia is running on 55amperes. He shud change to a higher output amperes.
Originally posted by pussy+Aug 25 2005, 01:50 AM-->QUOTE (pussy @ Aug 25 2005, 01:50 AM)
