Highline VS M-sport
If a recond unit, will the M-Sport word appear in the car reg card ? For Example, BMW 525i M-Sport 2005 ?
maccasel;372858 said:
guys,
just changed the wipers on my car...the previous one was damn noisy....so much so i tried not using the wipers until i really have too...it was bad..
now the new ones..slightly better...but still got that annoying squeeky sound...damn..:stupid:
try rainX.. it might help..:listen:
thule;372488 said:
mine so far ok nia... nothing wrong with the wipers.
Got myself a new non-run flat tyres as soon as these original ones go botak :D
thule,
what is the difference in handling and performance after u change to non-run flat tyres? thinking of changing to non-run flats too... can u share ur experience?
it's quite common for dealers, even naza to 'upgrade' their cars with the bodykit to pass as m-sport. If you hang around the bodykit shops you'll see many unregistered cars going for the upgrade. most ppl don't know what they're buying.
E60MSport;372116 said:
Also be very aware of fake M-sports. Usually can be easily seen with the chrome window trims. Some sellers say that a highline is an M-sport because of the bodykit, but look out for the chrome window trim and the M-sports steering
wat is the the chrome window trim?
Well as i know M-Sport is factory fitted NOT dealer fitted and as such you could actually checked via www.realoem.com by puttting in d last 7 digit or your VIN to determine whether you're getting d real deal or not as d website will pull out d parts and options that came with it :D
E60MSport;372832 said:
If you look at Highlines, the strip that goes around the side windows are chrome. M-Sports are black.
Yup ... msport version have wat is called 'shadowline' trim and cost a bomb around rm1700 for one side only :eek: thus why it's easy to spot a fake msport if there is one :D plus again check with www.realoem.com with your VIN number for verification cos it's a factory option :D
i ask raymond from Raymond Autowork n found that my 525 m sport year 05 is the early model. wat is the different between old engine n magnesium engine ah?
The older engine does not have Valvetronic at which it produces 192hp while the new engine produces 218hp. Displacement for the old engine was 2494cc where else the new one is 2497cc
hahaha :D
mine is the new N52 engine... 218hp..
BC23... wanna test ur car's power with mine? :D
thule;380591 said:
hahaha :D
like tat sure i lose lo haha.. urs is push start button 1 ah?
True ... d only consolation is dat d older engine is force-induction friendly i.e. supercharge or turbo fed unlike with d newer magnesium engine which can't withstand d higher temperature and pressure ...
p/s: 335i engine is twin-turbo and is aluminum alloy instead of magnesium :D
true...the 335i engine if not mistaken is the N54B30 engine which its block is similar to the M54B30 engine block which BMW decided more suitable for the turbo charging comparing to the N52 block design...
the N52 engine runs at higher temperature than the M54 so i think it would not be able to handle turbo or sc...
Nope... I think E60 models from the year 2006 and above will have the push start button...
the ones from Sept 05 onwards shud have the push start already...
thule how come urs dun have but u got the N52 engine? hehe
DOn't know la... haih... :banghead:
It'll look cooler with push start button...
hehe...u sure urs is with the N52 engine...kekeke
the engine cover shud be grey/silver type instead of black...
better check....
