Originally posted by Fireblade@Aug 15 2005, 05:23 PM
Sith,
Thank goodness your OK. Yes, I too am having a similar problem with my car; the damn wiper just stops working suddenly. This especially happens after I stop at traffic lights. Vigorously moving the wiper stalk switch up & down does not seem to work either. Then after a few minutes it starts working again. I've check & cleaned the stalk switch/connectors contacts and that doesnt solve the problem. Its most likely the wiper control unit, which has the speed sensor signal into it. There are a couple of relays + electronic components in this box. I wanted to replace the relays (soldered down to the PCB) but its not commonly found here. If you look at the parts catalog, you need to replace the whole unit - its under the dashboard on the passenger side. Its either you get a new one or get a reliable used one. I'm looking for one at the moment. In the mean time if it fails again then just pull over to safely park your car.
