Z zul_cessna Club Guest Joined Sep 15, 2010 Messages 114 Points 0 Dec 27, 2010 #1 Hi Guys, i'm having this problem, why sometimes my radio just quite for 1 second then it come back again, happened quite frequent, and the radio signal sometimes got interference.
bmw7833 Club Guest Joined Oct 14, 2006 Messages 9,160 Points 48 Dec 27, 2010 #2 Check the radio cable connection in behind. Or it hints u for something else..hehehh..
Z zul_cessna Club Guest Joined Sep 15, 2010 Messages 114 Points 0 Dec 28, 2010 #3 I know what you meant...racun arrr
Fireuz Club Guest Joined Dec 9, 2008 Messages 754 Points 18 Dec 29, 2010 #4 Have you check the antenna wiring.. It could be the reason.. Btw, which type of antenna is your car using? attach to body? horn antenna (usually for 328i yr 2000 AB)?
