Thanks AB, always been a helpful hand
Copy paste from the link on Tramlining:
"Tramlining is the tendency of a vehicle's wheels to follow the contours in the surface upon which it runs. The term comes from the tendency of a car's wheels to follow the normally recessed rails of street trams, without driver input in the same way that the train does. The same effect is sometimes called Nibbling.
Tramlining can usually be blamed on tires, and its incidence depends greatly on the model of tire and its state of wear. Although not normally dangerous, at very high speeds it can become a source of instability.
Vehicles with
large and wide low profile tires are more prone to the effects as well as vehicles which have wheels fitted that are larger than the manufacturers recommendation or have
reinforced sidewalls. People who are relatively inexperienced with driving with this tendency will feel that they have to make continual course corrections and it is very easy to overcompensate the steering, which could potentially lead to veering off the road especially if the road is a narrow track/country road.
The effects of tramlining can be eased by subjecting the vehicle to an
inspection and calibration of the wheels (i.e. a full geometry check) or replacing the tires with non-reinforced (soft sidewall) tires."
