handling problem for my e36
hentam77
hi friends,i own e36 97. tyre size 17" 225 45. spring standard. but my problem is when i drive, my car tend to pull right or left bila jalan yang tak rata. may be tyre problem or anti roll bar yang rosak.one more thing, mu e36 selalu kurang air radiotor. every week have to top up the water.please help.....
check your lower arm bushes and so on for item no 1 .... also perhaps if budget permits change those spring as your tyre size seems to be wider and running on standaard springs ...
2) low in water ....firstly change your radiator cap ....if still persist then check all the hoses condition , leaks and so on ..
changing radiator cap is the cheapest solution ....
hentam77;433474 said:
hi friends,
please help.....
i not relly expert with this.. but i this yg pasal air radiator tu slalu kurang maybe pasal bocor kut.. pg la check kat mane2 w/shop yg expert bout this such as optimum kat kayu ara tu... cheers
The situation you have with your car while driving is called tramlining. Go google it to understand further.
Many ways to minimize it, check on your bushings, ARB bushings, tie rods, steering rack, steering coupling, stabilizer rods, etc. Go have your alignment done after checking all these, if problem still persists after all these come join us for a cuppa & bring a tape recorder along:)
Change the whole expansion tank, check for leaks on the radiator. Also check on your engine fan to see if it is working allright.
thanks a lot guys for the valuable info...
anyway, my location at sarawak actually (kerja) and quite hard to find technical support... lucky ade this web site...
can improve my knowledge about bemmer...
if ade plan trip to kuching, just inform me....
What size rims and tires are you using? On smaller rims (15" or 16") you can play around with the tire pressure to minimize the effects of tramlining.
The wider your rims are the more apparent the effects will be. It's unavoidable no matter what fix you try.
one more thing,
my e36 front's height mcm tak sama tinggi je.... how? is it possible that kind of problem occur?
u r right..there's a different in height for left and right side.usually right side is slightly lower than left side since the car battery is place in the right side rear bonet.:wink:someone pls correct me if i'm wrong:top:
