RR78,
Just do the following:-
1. Go to "Setting" Menu.
2. Click once and "GPS Path" icon.
3. Click "Storage card" folder
4. Select "Papago" folder and Select "OK"
5. Navigate in the Papago folder and select "X5SE_800x480_C2_B9600.exe" and press "OK"
6. The GPS should update to the above ".exe"
7. Press the "HOME" icon (look like a house) and press "GPS" icon. Your Navi program will be invoke.
p/s there is a slight delay in the papago navi program. Reason is that it is setup as C2 and 9600 baud rate. Hence the updating is
a bit slow. whereas the iGo is set to Com2 and 57600 baud rate.
Trying to set papago to baudrate of 57600. WIP.
p/s. do the above if you want the i-Drive skin by selecting "WolfNCU" folder and "WolfNCU.exe"
