Anyway went to autochild last Sat and ask for the injectors to be clean up.
Yup, it cost about RM50 for each injectors. Meet Brendan and he seem very helpful in all the query that you might have. The workshop area is ultra clean.
They took out the injectors and did about a few tests on the injectors.
1. Equalization Test
2. Flow Test
3. Spray test
4. Backflush
5. Autoclean
After they comfirm that the injectors are working fine, the soak to injectors in
some solvent and immersed it in the ultrasonic cleaner (did it on the front and rear side of the injector)
After that, saw some other cars did the decarbonizing. So gatal also try that coz it cost about RM89. The process involved spraying atomozing solvent into the throttle body when the engine is running. Saw alot of black smoke and white smoke came out from the exhaust. Most probably cause when the AFM is removed.
Total cost including Solvent and Service RM354.
Oh yes, the engine is smoother and pickup is better.
Basically, quite happy with the works.
Pro.
Clean workshop
Helpful and Professional service by Brendan
Have a lot of specialize equipment for various work. (coolant replacement, brake fluid, ATF replacement, injectors cleaning,air con etc)
Con.
Very Slow (was there at 12pm and left at 5 pm)
2 helpers only but look like still under training
pricey as compare to other workshop
BTW, saw some aftermarket air filter selling for RM180 (about double the normal price). it look like spoonge but is washable by water. I think the name is "crossplex" or something like that.. Does it work?
