TheTinkerer
- Sep 10, 2012
- 170
Hi all,Any of you find that your F30's air con vents are loose? "Loose" as in, its not sturdy enough and sometimes will make some creaking sound just like some cheap plastic not fitted right. I noticed that other BMW models have thicker plastics for their air con vents and very solidly built whereas the ones fitted in my F30 is thin and fragile. Adjusting the air flow is very easily done and doesn't feels solid. On top of that, I suspect that the creaking sound that I hear during my drives also comes out from the air con vents. Any of you also experiencing the same?Edit: To be exact, those are cracking sounds where at times, could be quite loud.
