jasonnn;413304 said:I've not changed the wiper blades before, but I noticed the E46 ones has a "spoiler" attached to the wiper blade..
where can we get the exact same ones? does the bosch ones comes with it?
the beauty of it is , you use your old frames... just change the blades.. so much cheaper immediately and also long term...(on my old honda,it's been there 8 years already!!) they'll do it for you for free... with guarantee n warranty.. so much confidence in their products..saat;412435 said:But Duratec is the normal framed design.
nazrie;413394 said:the beauty of it is , you use your old frames... just change the blades.. so much cheaper immediately and also long term...(on my old honda,it's been there 8 years already!!) they'll do it for you for free... with guarantee n warranty.. so much confidence in their products..
Jarance, those polarising effect is most probably also due to using windscreen cleaning solvents ..especially with some solvents(not all) that were used to rid of watermarks.. they tend to have that effect.. when u get a new screen, just use newspapers.. the ink and chemical of the paper is good enough.. from the way of the polarisation seen , u can see swirl effect.. if due to wipers, it will just be linear...
c-square;413486 said:A bit off topic but may I clarify what is the function of the "spoiler" on the wiperblades, which some of you mentioned in your earlier posts?
BlackCat;413502 said:Its all about streamlining = better drag coefficient, reducing wind noise, visual cosmetics [? some might agree], etc etc etc...
saat;412621 said:Bro,
Since no one posted where these can be found and there are several perosns asking, would you like to tell us where you got yours.
thanks
saat;413500 said:It is a small inverse aerofoil shaped flap placed in front of the wiper blade. Aerodynamic pressure on the aerofoil will be transferred as downwards pressure pressing the blade harder against the screen especially at high forward speeds. This ensure better contact between the blade and the screen and thus better wipe and prevents lift-off.
They vary in size. In the case of the E46, it is about 12x3". In some cases, the spolier is attached to the arm whilst in most cars, they are attached to wiper blade frame. In both cases, it swings with the blade. Those where the spoiler is attached to the frame, the set comes with the blade, frame and spoiler e.g. E46. In most cars, only the driver side wiper has the spoiler. See the illustration - Spoilered Wiper Blade attached.
In the frameless design, the spolier is integrated all along the wiper blade as a countoyred shape. The prevents the need for separate spoiler and also offers even contact pressure all along the wiper blade. In the case of the normal spiloer, most of the downward pressure is concentrated on the spolier region. See Illustration - Frameless Wiper blade attahced.
Caveat - I am not a wiper blade salesman.
saat;413441 said:I wanted the frameless design and I make it a point to change my wiper often cos I reduce my already fast speed only slightly during rain. I am not looking at saving money but more about ensuring that they stay optimum all the time.
saat;412283 said:Did sumore research. In the US the frameless ones are called Icon or Evolution but in UK and Malaysia they called Aerotwin. The Icon has a more pronouced spoiler whilst the Evolution has a more generic spoiler design that works both ways..
Mikeong;413659 said:Jason you could try PIAA they do have it.
saat;413673 said:The problems is - tell me where to find them?
