calyon;200414 said:any good bm-specialist shld be able to. i recalled he mentioned some technical terms that day, which says like the RH sender shld measure up to the half gauge level then the LH sender measure from middle to full gauge level. coz basically ya fuel will fill up the RH tank 1st then flow over to the LH tank. so u need to constantly move both the arms' level under stimulation to see any error or misreading. apparently if i sender good n the other not, u'll not get pinpoint accuracy. ya workshop shld have tested all possible extreme reading before he affixed back the assembly (i.e. LH max up + RH max up, LH max down + RH max up, LH middle + RH max down, etc... then compare gauge level)
yes, n i spent the whole afternoon seeing that *.I.* (almost doze off)
tank34;201446 said:Hey Jarance,
i've got a "used" pump+float for sale ??)))) Me feeling is that the Pump is working ok, if you can fix the variance on the sender unit, you may have an interim solution.
tank34;201481 said:Jarance, the original fuel pump and floater were in the car for about 63,500km before I got the "Erratic fuel reading". Just so that we are in-sync, my car is a E46 325i 2003 model!.
jarance;201420 said:It finally happened to me.. My fuel pump went kaput after 240,000 KM usage last Saturday. Try calling a few shop but out of stock. Finally went to chopshop but also could not get the parts. (quoted RM320 for used fuel pump and sender)
Left with no choice, I did the unthinkable... eh.. I bought a japanese fuel pump (RM80) and retrofit it to my car on Sunday. Trial run from Klang to JB.. not much problem.. Feel a bit of lack of pickup but that is my feeling only..
Now looking for an ori pump.. Anybody want to sell their pump!!!
