Three18, are u sure u're using GT1 to check? It is supposed to be a real computer one (usually laptop thing), not hand held one. The hand held one is usually generic equipment and do not give detail error of UDM. I sudah kena kencing before...
To share, sorry kalau panjang sikit. mau tolong saja
Used to suffer like yours (sama symptom):-
Initially, i changed my fuel regulator - did not solve my problem. Then change fuel filter - problem dissappeared.
Then, engine always died when restarted again, especially at traffic light, engine died when pressing the accelerator and no power at all (itu RPM did not want to climb above 2,500). Thought MAF sensor, but scared of making expensive error, decided to investigate
I used to preservere several months before I could get my time to diagnose with GT1 and woila, my problems were only 3; camshaft sensors error (change camshaft sensors), thermostat error (change thermostat) and solenoid for electric valve for secondary air error (sudah order from Germany belum sampai). Since the camshaft sensors were changed, my problem solved. Its the darn camshaft sensors (mech said ini biasa kalau old sensors punya model). Baru punya, nampak ada lain sikit, ada muscle and hopefully last longer.
Lagi satu usually oil pump components. so many and usually GT1 did not pick up. so good luck in searching and hunting the problems.
