Engine shut down?
From what i know, the fuel filter is suppose to be change at every 60k km....or maybe once every 2yrs.....this is what i'm practising for my UDM....but when it's time to kaput, your pump will be kaput no matter how...
good practice to keep the fuel always above 1/4. The fuel pump gets hot if it is not submerged in fuel. This will kill it quickly. Also check the hose connecting both left and right fuel pumps.
The fuel pump should be changed every five years(normal use). Another one to check is the fuel pump relay.
fuel pump, people usually just replace the motor only, :34:
soo you guys replace entire pump? :eek:
How do you replace just the motor for the fuel pump?
Have you done it before?
i am confused, did you all people replace entire pump unit?
how much for the cost ?
Yes, not only the entire but also the fuel sender even though it is working.
If you dont know that, then you dont know much about E36 fuel pump.
Sorry, I cannot help you for being confuse. maybe you should plugged yourself into your diagnostic tool and try to see whether there is a bug residing somewhere in your body. :stupid:
soo how much did you spend on it ?
jarance;398824 said:
RM180.. DIY :listen:
No doubt, Joker is always here to confuse people :) but bro Jarance, RM180 for DIY? U mean DIY on a dead fuel pump? Joker, didn't mean to be harsh but at least Jarance proved that he knows the fuel pump of a E36 better than you. He had actually helped me out on this in real life.
Joker, why don't you prove yourself by doing whatever you need to do on a volunteer's car F.O.C, then dyno test it and show it to the whole world? Of coz, the volunteer needs to be an independant party agreed by most of us here :)
i replaced the completed fuel pump with the upgraded fuel pump
version few month after i got the car.
i still have the previous pump. Till now the pump was running.
Joker, no worries, I have started something for you.
Check this out, http://bmwclubmalaysia.com/forums/showthread.php?t=25672
But I suggest you do not post anything there, wait till we gather feedback, ok? Good boy.
My car engine shuts down today twice while idling, engine crank once and starts, what could be the problem?
JOKER;399311 said:
RM180.? the product was locally manufacture?, or from TAIWAN/CHINA/JAPAN/KOREA?
or it was US$ 180 ?
Why are you curious the price? It is RM180. How much did you pay for your upgrade?
I thought you can change the motor of the pump. I like to know how did you manage to repair the motor of the pump.
Bro, I thought you say you can repair the motor. Now you say you replace the pump with a performance pump.
How much did you pay for your performance pump.
Please check your AFM or ICV.
BTW, is your engine RPM steady or erratic. Sometime a vacuum leak could be cause.
beemer04;399469 said:
The RPM was steady, This morning my wife drove the car to work, so far ok.
In that case, it is the vacuum loss. Check all the rubber hose from AFM to throttle body.
and this..
you are blunted people already, actually i replace the entire system, upgrade the system.
soo, next time if the pump/motor fail,
i just to replace the silver metal cover MOTOR and small pump only.
too damn dumb already..., the old original fuel pump system prone to fuel starvation..
that why it need to replace frequently.. too damn dump...
bloody damn dumb :stupid:
i cannot withstand anymore damn dumb of community.. it is a terror nightmare...
no wonder the ASIA became asshess
