affan66;398409 said:good practice to keep the fuel always above 1/4. The fuel pump gets hot if it is not submerged in fuel. This will kill it quickly. Also check the hose connecting both left and right fuel pumps.
The fuel pump should be changed every five years(normal use). Another one to check is the fuel pump relay.
JOKER;398486 said:fuel pump, people usually just replace the motor only, :34:
soo you guys replace entire pump?![]()
jarance;398529 said:How do you replace just the motor for the fuel pump?
Have you done it before?
JOKER;398723 said:i am confused, did you all people replace entire pump unit?
how much for the cost ?
jarance;398794 said:Yes, not only the entire but also the fuel sender even though it is working.
If you dont know that, then you dont know much about E36 fuel pump.
Sorry, I cannot help you for being confuse. maybe you should plugged yourself into your diagnostic tool and try to see whether there is a bug residing somewhere in your body. :stupid:
JOKER;398820 said:soo how much did you spend on it ?
jarance;398824 said:RM180.. DIY :listen:
JOKER;399313 said:i replaced the completed fuel pump with the upgraded fuel pump
version few month after i got the car.
i still have the previous pump. Till now the pump was running.
JOKER;399311 said:RM180.? the product was locally manufacture?, or from TAIWAN/CHINA/JAPAN/KOREA?
or it was US$ 180 ?
beemer04;399381 said:My car engine shuts down today twice while idling, engine crank once and starts, what could be the problem?
jarance;399453 said:Bro, I thought you say you can repair the motor. Now you say you replace the pump with a performance pump.
How much did you pay for your performance pump.
