seech
- Dec 21, 2006
- 982
Anyone experienced before?My E34 M50B20 overheated once when one of the hoses tercabut so I had the head (or issit block???) skimmed and a new head gasket put in. Ever since then the running temperature seems to be higher than it used to be. Before, the temp needle was always on the left of the center mark but now when it is hot outside and with the A/C on, the temp is slightly right of the center mark.Its been like this for a while now and no major issues but recently while stuck in a jam, the temp started to move up to the 3/4 mark and only went down after the radiator fan switched to high speed. Even so, the engine really loses power when it is hot. In the early morning or at night power is good (for a pathetic M50B20) and temperature is normal but in afternoon and in a jam it gets hotter and loses power.I read in the New Strait Times CBT that cars which had their heads skimmed tended to run hotter due to increased compression due to the loss of some material from the head/block from the skimming.Has anyone experienced the same thing before? Any solutions? Was thinking whether a thicker head gasket would help but I have no idea how much was removed while skimming so how to measure the gap properly?As a last resort I am seriously considering changing the engine.Pissing me off as I have just spent a small fortune (for me at least) to fix the gearbox up. Now that's perfect and the engine is giving problems. Really Banyak Makan Wang.....Any help or advice would be most appreciated.
