Engine oil change
Shell Helix Ultra Fully Synthetic can ahcive up to 15000KM..... haha
i change my engine oil every 3 months....
but i'm using semi synthetic right now becoz of the valve lifter's noise...
hydraulic valve lifter use fully synthetic no problems at all...
RPM goes lighter & smoother.....
bro kinaka,
how much is the Shell Helix Ultra Fully Synthetic?? n.. is e36 use hydraulic valve lifter??
-G Punk-
1. Q8 4x
2. Shell 1x
3. NASA GD11 1x
4. CHEMLUBE 1x
5. Royal purple 1x
6. Mobil1 gold 1x
7. Castrol Magnatec 2x
8. TOTAL (semi-syn) 1x
:nyehehe:
i believe all the above listed oils are good provided you do a regular oil change and not to abuse it over to it's viscosity life span....
like for me a 45days is just too good and keeps my ride movin healthy....
:D
:D
Aiyo 45days oil change can cause pollution level too high la :D :D
1. Q8 4x
2. Shell 1x
3. NASA GD11 1x
4. CHEMLUBE 1x
5. Royal purple 1x
6. Mobil1 gold 1x
9. Shell Ultra
Hi all,
CASTROL MAGANTEC is enough for my baby.
Tried WURTH semisynt before but not much different.
Haven't tried any full synt oil. I thougt Full synt oil is not good for old engine?
Originally posted by noy_bimmer@Oct 13 2005, 02:22 PM
Hi all,
... Full synt oil is not good for old engine...
dat's wat ppl often say but if u ask y? dey giv dun really kno.
I'm believe in using thick full synthetic oil for old engines. Fyi, there's a thread on "In Search of The Right Engine Oil" dat u cud read up. :D
All, thanks for ur voting and feedback. Since, Q8 received highest vote, so i've done a survey in the website to understand more bout this product. Not sure either all this range available in local market bcoz this is from international site. Just want to share with u guys. B)
For Passenger Car Engine Oils
1). F1 10W-50
A full synthetic petrol engine oil developed for the British Touring Car Championships. It offers the ultimate protection for high performance petrol engines.
2). Excel EDX 0W-30
Excel EDX is a full synthetic, extended drain engine oil, that is designed to improve fuel economy in both petrol and diesel engines. It is especially recommended for use in the latest generation VW/Audi engines fitted with an extended drain interval indicator.
3) G Long Life 5W-30
A full synthetic, passenger car, extended drain engine oil specially formulated for the latest General Motors group passenger car gasoline and diesel engines with flexible oil drain intervals. It demonstrates fuel consumption saving characteristics and can also be used in all engines requiring ACEA A3/B3/B4 engine oil performance quality.
4) Excel 5W-40 (API SL/CF BMW Special Oil)
A full synthetic 5W-40 lubricant designed to improve optimum engine protection. Its low viscosity, high quality formulation, helps increase fuel efficiency and release engine power in high performance motor cars. Suitable for petrol and diesel engines.
5) Techno 5W-30
A part synthetic, fuel efficient oil for manufacturers who require this level of performance and specification. Techno 5W-30 is particularly suitable for high performance motor cars with multi valve engines and catalysts. The preferred engine oil for all modern Ford power units.
6) Motoroil 505.01 5W-40 (Merc B Special Oil)This part synthetic engine oil is specifically designed for Volkswagen direct injection diesel engines equipped with pump unit injectors. However, its high specification also makes it suitable for all vehicles that require the quality levels of ACEA A3/B3 or API SJ/CF.
7) Advanced 10W-40 (BMW Special Oil)
A part synthetic engine oil for high performance petrol and diesel engines. It improves fuel efficiency, reduces oil consumption, eases cold weather starting and reduces engine wear.
8) Plus 15W-40
A mineral based oil that meets Europe's toughest engine tests. It is suitable for all types of driving conditions and reduces exhaust emissions and oil consumption. It protects engines even at the highest temperatures and is suitable for petrol, diesel and LPG engines.
