Engine belt woes
affan66
Founding Member
Hi all,Just wondering if you guys notice or track your spending on replacing engine belts (aircond/alternator/fan).I have all my engine parts, services and labor recorded on a spreadsheet and noticed the following:For the past 2 years and 6 months of use of my E36 325i, I have replaced these belts more than 5 times. Is this normal? Every time I found the belts cracking and needs replacement.BTW, the belts are all Conti-tech.Thanks.
Affan66 wait for the sifus to answer, for me I change my timing belt at 40k and other belts at 80k so far I don't see crecks, I use Conti too and demanded to get the lattest belt I meant baru sampai one.
for the past 2.5 years with this car, I have only clocked 28k kms.
Just like rezzy3181, I replace my timing belt set (belt, tensional bearing, cam shaft oil seal & crank shaft oil seal) at every 40k km, but for other belts, will only replace them if I find cracks on it (usually about 50k - 60k km).
28k kms change 5 times :blink: !! Could be due to worn cam-pulley (happen to me once) or wrong tension apply during installation, which causing the belts to worn sooner.
Also could be due to imitation belts!
Hope this could help :) .
the pulley, tensioner seems to go on the M50 n destroys the belts. M-speed has quoted about 6-700 to get them replaced.
Affan is it the air cond belt or the water pump?
all the belts.
And I have replaced all the bearings and tensioners early on.
Anybody else have similar problems?
Bang pakai belt jepun lah, MITSUBOSHI etc....... ;)
Conti- tech are always prone to cracks. You can check the size of the original belts against the jap's belt see if they are available, i think they should have it. My E30 dunno where my mechanic got Mitsuboshi belts, all my belts he uses japs belt except for timing belt ehheheh
I replaced all the belting like you said and it last me more then a year already. 5 Sets for 2years?... That is seriously big problem..
jbk
