E90 to E60
jwah;793219 said:
Yes, you can get the non RFT and the slime tyre repair kit RM80 or mobility kit or a spare tyre at RM1600.
Very comfortable the normal tyre. I am on PS2
I ditch the RFT is because the thread wore very fast. After changing to non RFT..good
on RFT your tyre pressure shall be front 34 rear 36
Ok thanks for your info bro. It really help me a lot .
Gan_24;793026 said:
Yes you are right. I will change the spring first if still the same I have to change absorber .
This months I already top up 2.5 L of engine oil until today.not all because of leaking the valvetronic motor also one
Of the reason I think .
Check your valve seal and oil separator. This could be major contributor to engine oil lost
Ic noted thanks.do you have any idea how much is the repair cost?
Cost will depend on how severe is the damages to the engine. Mostly top overhaul will do. It will cost from 3-4k
Gan
Please pm me the place and hp no where you got the mobility kit and tyres.I like to change to nonrft also later.So far tyres can get from Wan Auto Bangi section 7 for rm800 each
Bro, I am still with RFT .I am not sure where can get the mobility kit.But I have seen it some where .If I manage to get it sure I will let you know.
Ic after change it I think can solve the leaking for few years.Thanks Bro.
Astro, i like your signature. Welcome to the cute signature family.
where to get slime tyre repair kit?
Just bought e90 320i 2006. Found oil on engine down cover, start about 5 min, ramp the engine white smoke come out. what is the possiblem problem, still inder warranty, left one week to complain, battery just kong after six years use by previous owner, I change to din100, after retune I fill jerking and after stop still canfill the nerking. Anybody can advise what is the problem.
