E90 cover below the car
Seong393
Hi sifu,My car cover below the car just break due to hit something in highway..3 pcs remove at Tamar shop. Do I need to do any replacement for the cover or just let it blank at doen of the car.1st pc cover down of radiator2nd pc cover steering rack and some of the pipe3rd pc cover auto oil filterIf replace how much for the cover and where can order?I'm in Penang..Thanks
The cover functions to facilitate the air flow under the car and will contribute to aerodynamics. The other function is to prevent from flood water to come into the engine bay if u happened to go through it. It needed to be replace other wise your car may not be efficient as it was designed to. Cost of the parts at AB will be around RM 600 +
if just left it blank will cause any issue?
If sand and dirt goes into moving parts then you will start to see the issues...
TLC your ride bro....would you want your 'bottom' to be exposed? :wink:
Some call it splash guard, to keep the engine clean, away from dirt and grime, apart from improve aerodynamic of the bottom air flow. It also protect flying gravels and stone from hitting and damaging the oil sump, oil cooler tube and also our plastic ZF transmission pan.
just now i checked with bavarian auto , item no 2 was quote at RM47+.
maybe i should go for custom aluminium
Hi there, I just crashed my car , also looking for the bottom large plastic material cover at auto Bavaria at sg besi, and quoted for rm 1.7k, my model is 11 e90 latest lci 323 . As I see above u guys quoted price are really far different , wonder how can it happen? Anyone changed it before? I would like to know the price for the original part. Or mayb I can get counterfeit part? Please advice, thanks.
Bro...I replace in tian siang which is one of the authorize BMW dealer also..cost me rm871 include labour..
Bro custom aluminum will cause ur engine heat increase lah
You can check with bmw parts supplier Bavaria Auto for the bmw parts price.
http://www.bavarian.com.my/
I believe the aluminium will act as a heat sink that will dissiminate the heat of the engine, correct me if i am wrong
Patrick23;801090 said:
Seong, u mean only The big cover cost u rm 8xx?
You may check with AB Jalan Tun Razak, was quoted rm 680. N46 splash guard. If yours is N52, should be 800+
Please note mine is for msport bumper. The fitment of splash guard depending on bumper. Price is varies depending on model.
Metal bends easily. Then disrupts airflow. That is why ori is not metal.
