Schwepps;508286 said:Yes, applies to all modern cars.
rastamarley;507587 said:during cold start its happen becoz the engine is cooled down n the fuel is not delivered to the engine injectors if its happen all the time the problem might be the high pressure pump , if there is no fault code on DME the problem might be normal .....
cheerz
danc;508348 said:I guess the choke is not so much a button but a lever that you pull. Hmm good old analog days ....
achtung;508360 said:finally diagnosed the prob, its a faulty fuel pump.
achtung;508360 said:U were right rastamarley bro
finally diagnosed the prob, its a faulty fuel pump. there is a loss of pressure after a while. so don't get a clean start until the pressure builds up again. getting a new one tomorrow.
so if u do hv long cranks and fluctuating rpm after an overnight there is something wrong !!! coz i never had it before. usually leave the car for a couple of days never start and never had such prob. always fires up instantly.
will know for sure once change tom!!! cheers
Schwepps;508434 said:Izzit? I thought it's a button...![]()
viewfinder;508471 said:Unfortunately it not just a faulty fuel pump fuse... but glad to hear it's fixed now.
What was the mileage of the car when the fuel pump issue 1st occurred?
rastamarley;513975 said:might be normal on cold start car misfires abit bcoz of the fuel not reach to the engine yet and the engine oil is on the oil sump still , even my car have the same problem and they said its normal n they just update the latest software for me on this problem i faced on my e90 as well ,
achtung;509156 said:guess what..prob still there. back to the service center.:motz:
at least got a 320d as a courtesy car :top:
pearl90;519220 said:Hi bro... i am also facing the same problem with my 325 recently, but worst is, the engine dies off completely when i slowed down the car. imagine this... i had a few times engine died off while slow cornering and suddenly steering and brakes does't work anymore. with cars trailing behind me its very scary!!!
this normally happens during cold start. after i restart the engine, its ok... do you have the same experience?
did they managed to fix your problem?
