S samtey New Member Joined Jan 18, 2016 Messages 11 Points 0 Dec 26, 2016 #1 Car vibrate especially when car is at full stop, rpm needle unstable, feels a bit under power, weird noise from engine! Dear sifu!!! Need help on the above urgently! Please assist!!! Thank you!!!!
R ridhuan82 New Member Joined Aug 18, 2014 Messages 32 Points 0 Dec 27, 2016 #2 Bimmer E90 said: Car vibrate especially when car is at full stop, rpm needle unstable, feels a bit under power, weird noise from engine! Dear sifu!!! Need help on the above urgently! Please assist!!! Thank you!!!! Click to expand... - If the rpm is unstable, try check the plug / coil. - If the steering/dashboard vibrate, try check your engine mounting Sent from my iPhone using Tapatalk
T Tiaraz Residence New Member Joined Jul 15, 2016 Messages 25 Points 0 Mar 30, 2017 #3 What mileage? Has check error code? If more than 100k km should consider replace spark plug 1st
D DanzE90 Club Guest Joined Nov 6, 2013 Messages 296 Points 0 Apr 6, 2017 #4 i experienced before, car was shivering during idling & RPM fluctuating, at time car dies while idling too, had to clean my intake, change spark plugs & 1x plug coil that was broken.
