E90 320i engine suddenly stop when driving
subraputra
Official Member
My e90 suddenly engine stop.I drive pop up transmission problem dcs problem tfm problem.try to start back cannot then after wait about 10min the car can start back like normal check the idrive error nothing.then i drive about 10km I stop the car try to off the engine then start back same thing happened again after 10min come to normal.what could be the cause.....
subraputra said:
Check ready OK no water in battery area
Sorry, no water in the battery or no water in the battery compartment?
What about the cable terminal?Are the cable tight or loose?
Did u went into any minor accident recently? I had a friend who's e60 had similar issue, he had a minor accident at his back.. happened to be his abs sensor faulty which induced other faults to come out. His car did not stop though but cut off at 20km/h.. he stopped, turn off the car, n start after bout 20mins, then could drive back..
Sent from my ASUS_Z010D using Tapatalk
I suspect the dme relay giving problem so I replaced the new relay blue colour so far the problem never happen again after stop and start the car few times will monitor and update in the forum
