Mouse
- Jan 1, 2006
- 1,679
- 38
guys, just need to check if anyone had similar problem. during D mode, if you shift your gear stick to the left, it will go into S mode. however, mine will show M 1 instead of S, it will remain in M 1 even if you shift upward to M 2, M 3 or M 4, in conclusion, it will not shift and keep sticking to M 1 and your rpm will go all the way to redline until u kickback to D. gearbox no problem in D mode, gear changing smooth and everything like normal. any idea what is wrong?
