E46 Projector Lamp
Hi Guys,
I received a few pm on the bosch projectors so I just post my experience here.
There are 2 bosch projectors - facelifted E46 and non facelifted E46.
The facelifted E46 cost about mid to high RM 5K while the non facelifted is around RM3.5-3.8K last I checked around 5-6 months ago. They come in black or titanium trimming for the facelifted projectors.
This price is for parts purchased from 3rd party parts vendor such as First Division or Bavarian Auto. If you buy from Auto Bavaria it will cost in the region of high 6K.
I installed the Bosch Xenon projector for my facelifted E46 so I just share my experience here.
Bosch Bi-Xenon Projectors BMW part number:-
63126910971 - Bi-xenon headlight left side
63126910972 - Bi-xenon headlight right side
The facelifted projectors are bi-xenon projectors. They are not to be confused with dual projectors. The bi-xenon is a projector capable of low/high beam projection using a single projector light. But since this is a retrofit you will only get low beam xenon projection. You will need to do further DIY wiring to fully unleash the bi-xenon capability of your projectors. Details of the extra wiring and necessary components are posted in another forum and you need to register yourself to access to the electric block diagram. Do this if you are well verse in electronics or have a degree in EE. :D
Also you will not get projector self levelling feature for the retrofit. To enable self levelling feature you will have to buy the mechanism and wiring. The mechanism involves placing sensors along the vehicle suspension so it may not be cheap.
Pros
1. Excellent built and finish quality - No water leaking problems with high quality plastic moulding
2. Excellent light throw - far,wide and even light throw. Being original equipment the light throw arc is correct - that is the arc is bias towards left side illuminating driving side of the road.
3. Well designed ballast. Ballast screwed in nicely and neatly underneath lamp assembly housing (compare to after market, which u need to hide the ballast somewhere) so it is plug and play installation.
4. Original D2S HID bulbs around 4300K or 4700K. This bulbs produces yellowish white beam with high lumens. The higher the kelvin temperature the lower the lumens. So those bluish/purplish bulb will give u very low brightness. Effectively useless during inclement weather.
5. Projector chrome housing finishing is much better and you get the word "xenon" on the projector instead of depo.
Cons
1. Very expensive compare to Taiwanese replicas
2. Original bulb is yellowish-white. Most people prefer whiter HID around the region of 6000K
3. No built-in angel eyes.
4. Light throw cannot be adjusted internally if you reset computer after installing projectors. Adjustable if you do not reset computer at the expense of a annoying warning light in your cockpit. Or you can do some bypass like what kat8186. This tricks the computer into thinking that everything is all right. I never tried it so I am not sure if it will work for Bosch projectors.
Light throw level only adjustable using a screwdriver by opening front bonet. But if the original adjustment is good enough you should not need to adjust frequently.
5. Small lights are yellow halogen so you get a white and yellow look when seen externally.
Hope this helps.
Originally posted by valkryie@Apr 19 2006, 12:22 AM
You can no longer adjust the light internally if you choose to reset your computer after installing the projector.
Let me know if you are interested to know more about the bosch projector. I stop here since you ask for taiwan depo projectors. :D
Aiyo! need to reset the computer after installing the headlamp eh? if don't want can o not? if not reset wht will happen?..if the Bosch projector have come with built-in angel eye..it is worth for consideration afterall if you add in separately for the Angel eye..the price is almost thr oladi. :getyourfactsright: ..The Taiwan Depo are quite good from the review tht I read in the lastest Hypertune magazine this month which feature the last part of BMW E46 performance modification upgrade...thr are some brief comment on their headlamp upgrade..So if they choose it must be after some thorough study kua...I guess boach will be the safest bet & i don't think you will go wrong with boach...after all I guess 30% or more of the parts you can find in the BMW came from Boach manufacturer.
Originally posted by valkryie@Apr 19 2006, 04:43 PM
Cons
2. Original bulb is yellowish-white. Most people prefer whiteHID around the region of 6000K
Hope this helps.
Aiyo..use Boasch oso got cons eh!! :eek:
The worst is No 4..which hv to go thru such hassle... :rofl:
BTW, thank you for your valuable info. :p
Hi Fire,
I suggest you check out the quality of the depo projectors first hand. The plastic moulding and finishing is not good but it looks pretty decent upon installation. Can't really tell from outside once installed. So from this stand point you can consider a depo projector.
There has to be a significant difference in quality of the components otherwise how to justify the price difference.
And adjusting the light throw level is one time thing. How many times do u adjust your level. I ask the shop to adjust it to mid level. Drive it around and it looks ok. Has been on this setting level ever since.
Not a problem. Unless you lower you car drastically and need further adjustment. Then u need screw driver.
:beaten: Oh...ok :yahoo: ..since only one time adjustment.. :p
Yeah lar. If I need to open my bonet and adjust the level everytime i get into my car I will also be like :beaten:
Cheers mate. :D
just sharing experience only. lots of research, trial and mistakes. not need to clap eheheh :D
Bro Yellow,
Thanks for the compliment. Does this mean that I get to sit in your SMG ride and test the launch control? :D
actualli we can "map" the paddle gear shift if u got the smg steering
to our steptronic
:D
to our steptronic
:D
Bro Leakwoon..
Heard some shops can do that mod.. But the feel will be different.. because steptronic run on automatic tranmission. Sequential Manual Transmission 'SMG' using manual gearbox.. to be specific Manual M-Tech gearbox. The 'stim' will be different.. :D :D Just want to share guys.. Tonite I'll be at Bukit Jelutong.. See you there guys..( bro valkryie.. projector Taiko ) ETA 9.30pm
Originally posted by valkryie@Apr 21 2006, 02:01 PM
Bro Yellow,
Can bro... How about at Bukit Jelutong tonite... :D
Bro Yellow,
Are you serious? Not a problem for me. You can check out my projector at the same time. :D
If serious put time put place.
Originally posted by valkryie@Apr 21 2006, 02:44 PM
Bro Yellow,
I'm sorry not tonite.. Is tmrw nite.. We can meet there..
I'll be here.
Originally posted by valkryie@Apr 21 2006, 02:55 PM
Bro Yellow,
That gathering is at 6 may. :lol:
Ok. See you next month.
Okay bro projector Taiko... Want to see your Bocsh projector Headlight la :D :D :D
