E46 Part and Service Cost II
Radiator gave way repair cost
Hi all,
Sharing my repair cost this month after radiator gave way.
car 346 325i, year 2001, mileage 85k
labour for oil service rm45
labour for radiator repair rm 150
oil filter rm42
oil sump sensor rm650
enginer oil rm 396
radiator rm 1,150 ouch!!!
thermostat rm195
top hose rm125
coolant rm 28
total rm 2770.75!!! ouch!
I was told my radiator is original BMW germany hence the cost. I saw a posting on a 323i radiator costing rm660. any difference?
regards,
energy
Tis morning while on the way to work, i noticed my RPM flatuating when stop at the trafic light. The car vibrate a bit also. While at the second traffic light, RPM flatuate between 500 to 1000. I quickly went to the office, check and reply urgent email than went to my mechanic.
Initial computer analysis review failure of the oxygen sensor before catalatic convertor, my mechanic said sometimes, if the hoses leaks, it will give this kind of signal also. Upon opening it up, it is true a hose is leaking, had it replaced and the car is fine now.
1. Hoses - RM 110
2. Hose clip RM 5 x 4 = RM 20
3. Labor - RM 80
Total RM 210.
http://www.realoem.com/bmw/partgrp.do?model=AL32&mospid=47631&hg=11&fg=45
he culprit is item 2 in the above link.
- 1 pc water pump $160.00
- 1 pc fan belt $55.00
- 1 pc air-con belt $40.00
- labour/out door service/rescue $120
Total : $375.00
cheap....considering that fact that it saved me having my ride towed.
Whole job done at my office carpark within 1/2 an hour.
Just change my aircon cooling coil & aircon gas filter,replace oil for aircon compressor & full refill gas....Total - RM1,353.10:cool:
I bought the cooling coil by myself fr Spore. way cheaper SGD$197. the workshop quoted way too expensive RM2,450. So I just pay them their labour with Gas top up & compressor oil RM570 total. & make sure u order gas filter too tht will save u further.. for 320i yah..u hv to open yr whole dashboard...but if yr are 318..u r the lucky lot....as it can be replaced without taken yr out yr dashboard..it take 2 day affair to get it fix. The workmanship are superb as they fix about 30-40 E46 per year so they know how to open/dismantling yr dashboard..& so far there r no funny sound from dashboard while driving ..anyway..318,320,323,328 r sharing the same cooling coil...quite a marvelous enginering from BMW..as one part suit for whole range of model...I mean they really got economy of scale on this... manage to have a short chat with the mechanic who fix up my car..say E46 aircon weakness is on the cooling coil as it is made from aluminium, it easily rotten which cause the leakages of gas..normal life span is 5-6 year for this cooling coil..the workshop is "u need aircon" at ellis road..
Work done at Mega:
Wheel bearings (2 sides, rear): RM220.00
Oil Filter: RM35.00
Rear Absorbers (2 sides, rear, bilstein): RM560.00
Labour: RM360.00
Mobil 1 (6 litres): RM254.00 (own)
Total damage: RM1429.00
Fan belt replacement at AB
E-46 318(2.0) year 02
Was driving 1 night then the fan belt gave way, so no choice call AB tow truck to send back to AB for service.
Toll truck to AB 100
replace alternator drive belt 22
fan belt 195.3
replace oil filter housing gasket 121
gasket 11427508970 18.03
gasket 11427508971 13.05
check power steering 66.0
Total 535.38
BTW my location is in JB
Top Power Auto Service Centre ( JB )
Wiper Tank Motor 105
Left Rear Power window Lifter 400
Total 505.00
Was talking to the owner of Top Power, he suggested that Engine Oil will not last
the 25K distance that AB claims also for 4 cyclinder 318, the engine will makan engine oil. Suggested change at 15k max. Show me the carbon build up at the oil cap. Also says that the L6 engine is the best, no problem. Also recommended Castrol or Esso.
Also suggest that the auto transmission oil to be change at every 100k. Cost at 68 per liter, needs between 12 to 18 liters.
Change ATF, filter and Gasket at Stuttgart
Hi All,
I have been going to Stuttgart because it is close to home. I think their charges are quite expensive though. Spent a fe grand last 2 months to maintain my 5.5 year old E46 325i, sigh...
-RM2,200 on a power steering vane pump and related stuff.
-RM2,700 on radiator and etc last 2 months.
Just changed my Gearbox ATF, filter and gasket there yesterday, just to check if the price I paid was reasonable or not. Please advice.
Labour RM 120
Auto filter RM 100
Gasket RM 50
Auto Oil RM 48 X 7 = RM336
Total RM 612 (including 5% service tax)
Ok ah?
Im just repaired my bimmer today in Tmn Mayang due to gearbox oil leaking.(E46.318i)
1. timing oil seal (45)
2. timing cover gasket rubber (55)
3. flywheel oil seal (72)
4. oil sump gasket (115)
5. timing cover gasket steel (180)
6. Labor (650)
7. Denso Iridium spark plug 4pcs (160) "beli sendiri and formen help installed"
total: 1117.00
By the way, are you guys normally drop ur car in workshop then ciao or wait till finish repair ur car?
Engine oil change Syntium 3000 LL 5W/30 4.25L RM318.75-->this oil is blardy expensive
labour charge = 44.
Filt Element = RM48.96
Filter = 217.62
Cleaner = 11.31
total 640.84
done at AB.
jurid brake pad e46 @ 135 for both front, didnt know jurid is under honeywell now (or all the while is under honeywell?) y did they camfered new brakepads direct from factories nowadays? cannot tahan coz too many exchange because of noisy pads?
Just got my bimmer service last week.
ATF + Gasket + filter rm 767.00
Change out power steering filter, fan belt (2pcs) engine oil + filter, wiper motor rm920.00
Total of 1687.00. (including 160.00 labour charge.
Done this in Miri, Sarawak.
The mechanic doing my bimmer used to work in Singapore BMW.
Just did my repair for my e46
1. Back wheel bearing RM 110 x 2 = 220
2. Alter. Belt Bearing RM 80
3. Alter. Belt Tensioner Bearing RM 205
4. E46 Ribbed V-belt RM 60
5. E46 Ribbed V-Belt RM 40
6. Labor RM 200
Total RM 1,010
Done at my regular mechanic place in Kuching
Did the following at M-speed today :
1. Engine oil change 7litre - castrol edge 5W40 : RM300
2. Wiper blades(2x) : RM120
3. Rear bulb carrier(left & right) : RM300
4. Expansion tank : RM300
5. Top hose : RM135
6. Radiator coolant : RM52
7. Front brake pads (ATE) : RM140
8. Micro filter : RM130
Total + discount : RM1450
Wallet very much lighter :( , but engine definitely smoother !:D
RM120 for a pair of blades, ouch...
My Visit to Dr Meng of MSpeed yesterday,
Coolant RM50
Hose connecting the Radiator RM135
Update software RM200
Next visit (month end to do a ATF change)
Service my e46 today.
Oil Filter - 35
Helix Plus 15W-50 - 5 Ltr - 110.00
Labour - 35
Total - 180
did my tire allgnment yesterday at hup shun sunway and the cost are as follows:-
allignment and tire rotating - RM40
adjusting of chambers - RM80
total RM120.
Hey bro...
1) Fuel pump & floater = RM500 + RM300 here over @ MSpeed...labor inclusive
2) Try changing the rear axle oil...
Hi all sifus,
This is my first time contribute to this forum.... Did my first service and some parts replacement today with Ah Meng a.k.a Kenny at Mspeed usj... below are the details:
First impression : Very friendly person
Location : a bit tricky at the first time, but easy to get there
Service : Castrol 5-40 fully synthetic + oil filter + labour + GT1 checking = RM150/=
Parts replacement : 2 x Camshaft sensor (RM800) + ATF change (RM600) +Delkor MF battery (RM430) + update software (RM200) = RM2000 (RM30 discount)
Total : RM2150 (ini bulan, wa makan loti loh)
Verdict : Smoother engine and transmission plus more pickup
Rec : Highly recommended as they performed the jobs professionally...
