Alex5522
- May 28, 2010
- 2,324
- 38
wingzee;801497 said:Headlight weather strip (rubber) x 2 - RM90 each side
Bro do you means item no 9 from the dia ?
Alex5522;801527 said:Bro do you means item no 9 from the dia ?
Alex5522;801532 said:Wah..so expensive this thingy ya..rm90 each ? Was this ori strip material like some sort of rubber made.
nice to know, and slightly cheaper is how cheap bro? thanks.jarance;795622 said:The E39 power steering pump is slightly cheaper and can also be used for the E46. Direct plug and play.
wingzee;803571 said:Did the last part of my cooling system overhaul today. Parts all bought from Bavarian Auto SS2?:
- Water pump (Saleri): RM115*
*OEM part. Material is metal composite. Saleri is Italian which OEM for Ferrari as well. Original BMW part costs RM310
- Thermostat (Engine): RM154
- Thermostat (Radiator): RM198
- BMW Coolant: RM30 per bottle (2 bottles required)
- Spritzer distilled water 9L: RM10
Do you means you get your Saleri Italiano made H2O pump with RM115 instead of original price
RM310 ?
Alex5522;803580 said:wingzee;803571 said:Did the last part of my cooling system overhaul today. Parts all bought from Bavarian Auto SS2?:
RM310 ?
Yes bro. Saleri is RM115 while original BMW is RM310. Almost triple the price.
Overseas forum all pointed that Saleri is in fact the manufacturer of the original BMW pump. Just that of course original BMW one got the BMW logo lah.![]()
Alex5522;803588 said:oh..ya find some info's about Saleri water pump from E46 Fanatics forum: http://forum.e46fanatics.com/showthread.php?t=906044
Btw i change my water pump wit brand TRW about 3 years back was RM115 too.
So consider you are getting a good price too bro.
swansonsz;803576 said:Wingzee, i assume the distilled water is to dilute the bmw coolant (again assuming it is a concentrate)?
Where did you do your servicing?
rwd;804105 said:Performed some basic oil change in Bomin
1. ATF,
2. ATF filter,
3. ATF service gasket,
4. Rear Differential Oil
5. Coolant
Cost: RM700++
Found engine oil leak (not so serious). According to Bomin, need to perform major service for "C" curve of the my M43 engine..Cost is about RM1000+-..is this a reasonable price?
subsonique;804418 said:just did mine yesterday at A&A Alam BM Auto at Baru Berendam Melaka. these are the guys from Seong Hoe Melaka who got out and opened a garage specializing in BMW and Benz.
1. Front shocks (Bilstein) - RM780
2. Rear shocks (Bilstein) - RM390
3. Abs mounting (front) - RM240
4. Abs mounting (rear) - RM120
5. Window right rear - RM195 (the window was stuck and jammed)
6. Lower arm (front left) - RM680 (not too sure which brand)
7. Wipers - RM195 (not too sure which brand)
8. Diagnosis - RM60
9. Link rod - RM115
10. Labor - RM250
11. Alignment - FOC
12. Fog light fixing - FOC
Total damage RM3025
overall, i am satisfied with the pricing and also workmanship. sent in my 330 at almost 11am and everything was settled by 4pm.
hey bro, if not mistaken the stock BILSTEIN is B4 right?wingzee;804556 said:Hi bro, finally got your shocks replaced? Any idea which Bilstein model are they? Certain parts may get cheaper eg. abs mounting but overall is quite okay.
