E46 Part and Service Cost II
Finally flused and changed my ATF plus others....
Auto Transmission Oil (RM60x11 ltrs) RM660
Auto Gasket RM 42
Auto Filter RM 64
Receiver Tank RM 300
Rocker Cover Gasket RM 98
Oil Seal (RM5.50x15) RM 82.50
Power Steering (Filter) RM 95
Radiator Cap RM 52
Power Steering Fluid RM 20
Labour
To machine Flush Auto Transmission Oil & Replace Filter & Gasket RM 150
To Replace Rocker Cover Gasket & Oil Plug RM 45
To Replace Receiver Tank RM 30.
Hi Guys,
Just collected my car from the workshop...........bill as follows:-
Wishbone Arm - RM1,120
O Ring - RM5.00
Sump Gasket - RM50.00
Labour 100.
driving seam a lot better after the arms were changed
Mileage 95409km
Engine Oil - RM377.00
Oil Service - RM44.00
Filter Element - RM53.37
Air Cond Filter - RM217.62
Cleaner - RM11.04
TOTAL - RM703.03
Service done in AB Sg Besi
My service done at heritage services
Oil Change : Hirev 9050 8 lite @ RM 310
Oil Filter : RM 40
Valve cover gasket : RM 90
Front Brake Disc : RM 820.00 (2X 410.00)
Front Brake Pad : (1set) RM 400.00
Spark Plug : RM 420.00 (RM 70 per piece)
Workmanship: RM 140.00
Service Tax : RM 7
Total : RM 2227.00
(all parts replaced are original bmw)
My ride is now almost at 65000 kms. On October 1st at 60k kms, I felt vibrations on my car seat when i am stationery at traffic light stops and also in auto D-mode. I called M-Speed & went in for engine mounting change:
2 pcs engine mounting RM330
Labour RM80
And so the damage is:-
Pulley RM155
Fan Belt Tensioners RM340
Intake Separator RM148
Labour RM80
TOTAL RM723
Changed rear bearings from Stuttgart
E46 Rear bearings - RM90 for one
Labour - RM 240
Total RM420 for a day's job changing rear bearings.
Hi,
Just done an oil services at M-Speed, Subang yesterday:
CAR SERVICES #4 - Engine oil, oil filter, labor - RM180,expansion water tank - RM300,thermostat - RM160, screw - RM15)
Total: RM655.00
The mechanic said it's good to change 'expansion water tank' every 60K km...
My brake lining warning light came on.
I sent my e46 to AB - Segambut and was RM1,147 poorer :(
Breakdown of my bill is as follows:
RM
Check All Pads and Disc Condition = 22
Replace brake pads of front & rear = 143
Linings (front) 1 pair = 432
Sensor front = 76
Linings (back) 1 pair = 380
Sensor back = 76
Plastilube = 9
Service Tax = 9
Total = 1,147
My question: do they have to change sensors everytime they change the lining? :dunno:
Just done mine in Wshop in PJ, oil leak problem (E46)
OIL Filter Housing Gasket (28), Engine wash(10), labor(50), Engine oil(47)
TOTAL: RM135.00
Was driving normally yesterday when i heard a very sickening sound which sounded like metal being dragged along the road. Got it checked and it appears that the driver side rear brake disc has worn out. Apparently you have to replace both rear discs although only one was badly worn out. I had it replaced at CKP Auto near BMWorld (Pandan Indah). Breakdown of costs are as follows:-
1) Rear Brake Disc X 2 RM640-00 (Original from AB)
2) Labour RM70-00
Total Damage today RM710-00
P.s. I was told by the workshop that they get a discount when they buy their parts from AB. They asked me if I wanted to buy OEM brake discs (from Germany) for about RM100 less each but I thought it was better to be safe than sorry when it comes to brakes so I asked for originals from AB.
My CNY 'present' from Auto Bavaria. The bill is as follows (and I would like feedback on the labour charges which I think is excessively high) :
Pulse generator - RM401.19
Checking function of DME - RM44.00
Replacing the pulse generator - RM11.00
Radiator pump - RM446.70
Housing coolant thermostat - RM324.34
Anti freeze - 57.28
Replacing coolant thermostat -154.00
Replacing water pump - RM198.00
Bleeding and checking cooling system - RM55.00
Fan belt - RM179.03
Replacing fan belt - RM66.00
TOTAL - RM1962. 64 out which labour cost amounted to RM558.00
hi all. bought my car (e46 328ci - 2001 model, uk spec, recond) in july 05. had 16k km on it.
oil filter - 38.00
air filter - 55.00
a/c filter - 130.00
fuel filter - 58.00
spark plugs x 6 - 180.00
automatic sump filter - 60.00
automatic sump gasket - 55.00
lower arm busg - 340.00
brake disc skiming x 4 - 120.00
p/steering container - 82.00
radiator cap - 38.00
axcel oil screw - 2.00
coolant - 28.00
reset central locking & computer - 300.00
engine oil - shell fully sen - 315.00
atf: esso - 336.00
excel oil - 30.00
p/steering oil - 25.00
brake oil dot 4 - 38.00
labour - 320.00
GRAND TOTAL - RM2552.00
Hi,
Just did the following at heritage for my E46 N42.
1. ATF Change + ATF gasket + ATF Filter + 7 litres of Esso ATF
2. Engine mounting X 2
3. Gearbox mounting X 2
4. Expansion Tank + Coolant
5. L/H Side Mirror (Heated Wide Angle)
Price: RM 2,000-00 inclusive of labour.
Gear shifts feels smoother and car does not sink/dive when shifting from P to D.
Hi guys,
Had a problem with slight vibration during idling & low speed. Diagnosed. Igniton coil problem at pod 2 & 3. At first wanted to change only two coils then being advised by mechanic i changed all four coils.
Cost:
Ignition coils rm200 x 4nos
Labour charge rm40
Now car better pick-up, power and zero vibration.
Parts
Oil filter RM34.00
Engine oil (Total Q9000) 2 x RM168.00 = RM336.00
Air filter RM50.00
Spark plugs 6 x RM30.00 = RM180.00
Auto gearbox sump gasket RM36.00
Auto gearbox filter RM56.00
Auto gearbox oil 6.5 x RM60.00 = RM390.00
Rear axle oil RM24.00
Engine vent air hose RM52.00
Radiator RM670.00
Radiator hose (top) RM130.00
Radiator hose (bottom) RM120.00
Thermostat RM210.00
Coolant 2 x RM28.00 = RM56.00
Fan belt RM182.00
Fan belt bearing (top) RM75.00
Fan belt tensioner (bottom) RM162.00
Fan cover RM143.00
Air cond belt RM119.00
Air cond belt tensioner RM152.00
Power steering fluid can RM80.00
Power steering pump pulley RM175.00
Coolant tank RM286.00
Steering side rod cover 2 x RM30.00 = RM60.00
Sub total RM3778.00
Labor
To oil service maintenance check and to reset oil service indicator light RM100.00
To renew spark plugs and air filter RM30.00
To renew fan belt, air cond belt and all tensioner RM120.00
To renew radiator, radiator hose, coolant tank and thermostat RM120.00
To renew auto gearbox oil and filter RM40.00
To renew steering side rod cover RM25.00
Sub total RM435.00
Grand total RM4213.00
My service done at M-Power Rawang....
Front brake disc - RM790.00
Rear brake disc - RM790.00
Front brake pad - RM480.00
Rear brake pad - RM350.00
Lower arm bush - RM450.00
Brake Sensor - RM120.00
Engine Oil Top-up - RM38.00
Labour - RM100.00
TOTAL = RM3118.00
After Discount = RM3050.00
*All parts are original BMW
I think is a bit overprice... and funny the disc share the same price...
just change a front lower arm bush cost me rm320 for a pair(lemforder)...labour charge rm80...issit expensive???
Airbag sensor light ON
repair :
driver site tensioner belt - RM530
labour + diagno - RM120
Got my brake pad change last week, front-EBC-RM170, rear-ATE-RM100, sensor RM30..........DIY at home, cheapest lah.......
ok. inspection 1 at AB today..
1. BMW Inspection 1 --> including body inspection and
old oil disposal(bullshit) RM 143.00
2. Replacing Fluid in ABS/ASC+T brake system. RM 44.00
3. Shell Helix Ultra AB 4.25L(BMW LongLife-01) RM 276.25
4. FIlter Element(OIL FILTER LA) RM48.96
5. Micro FIlter :getyourfactsright: RM 217.62-> cut throat price.
6. Cleaner RM 11.31
7. Brake Fluid rm56.88.
8. Car Wash FOC
total RM806.77 :cry:
