E46 Part and Service Cost II
Inspection II - 318i E46 2001
BMW Inspection II and old oir disposal RM 154.00
Shell Helix Ultra 4.0L RM 168.00
Steering Fluid 0.25L RM 4.50
Oil Filter RM 39.00
Spark Plug H RM 288.20
Air Filter RM 95.27
Microfilter RM 144.40
Windshield Washer RM 9.77
Fuel Filter RM 133.21
Bolt RM 9.97
Clamp RM 6.90
ADDITIONAL JOBS:
a. To renew Brake Pads of Both Front Disc Brakes RM 77.00
a. Brake Linings RM 382.10
b. To renew Both brackets for Control Arm RM 154.00
b. Mounting RM 613.02
c. To renew Alternator Drive Belt RM 11.00
c. Belt RM 150.25
d. Checking Ignition System With BMW Diagnosis System RM 44.00
Total Labour RM 440.00
Total Parts RM 1872.77
Lubricant RM 172.50
Total RM 2485.27
Service Tax 5% RM 22.00
Gross Total RM 2,507.27
Changed brake pads for front wheels today:
- Texstar RM200 for both sides (2 pairs),
- labour RM50.
just changed my alternator belt cost me RM 60 purchased at stuttgart
and sent over to my mech at Glenmarie was charged RM 20 labour.
Bought platinum 4 legged sparks each at RM 33 from Stuttgart and labour was charged RM30.
Coolant original BMW was RM 38 + RM 10 labour.
All labour services took place at my mech in Glenmarie BM Motor Service.
Renew 6 new platinum 4 at RM30 each/ total 180 + 30. done at jln ipoh
U might feel surprise with the new mounting :yes: trust me B)
These are the parts list here:
2 pcs engine mounting RM296
1 pc Rear diff mounting RM160
1 pc Upper head engine gasket RM 98
Total labour RM230
Total: RM784 nett
Changed sparkies : 4 units BOSCH Platin at RM31 each, plus RM10 installation.
Total: RM134.00
Stuttering problem solved! One of the hoses was leaking (no idea which one - forgot to ask! :rolleyes: ), so had it replaced and tuned. Damage RM280.
Then went to AB to buy some plugs for the door and dash trimmings - my trim fell out when Iwas driving! Lucky not when the wifey was driving!
Door trim plugs at RM3.00 each, 4 pcs for front door.
Dash trim plugs at RM2.45 each, 5 pcs.
Then got conned into buying a F1 junior cap at a heavily discounted price of RM45 (ori price RM135)
i think i hv been ripped off... spent RM355.25 for oil and filter on my E46 (2.0L).
1. oil service and reset service indicator light = 45.00
2. service tax = 2.25
3. oil filter = 45.00
4. mobil gold (5L) = 263.00
are these normal prices???
Just done inspection 2 and full service..the parts and prices as follows
oil filter (40)
Valve cover gasket (130)
Oil sump gasket (95)
Air hose (40)
Air Valve (195)
Radiator (660)
Thermostat (300)
Thermostat valve (160)
Coolant (25)
Bleeder nut (15)
Fan Belt (185)
A/C Belt (120)
Tensioner bearing (145)
Tensioner bearing (160)
Bearing (75)
Gearbox mounting 35x2 (70)
Rear Absorber mounting 40x2 (80)
Rear Absorber damper 30x2 (60)
Air hose (105)
Air hose (140)
Air hose (140)
Window lifter (390)
Bottom hose switch (130)
8 litres engine oil (310)
Labour (400)
service tax (20)
Total: (4090)
Discount (90)
Grand Total: RM4000.00 :cry:
Oil Inspection
BMW Engine Oil Service incl Add Service RM 33.00
Cleaner RM 11.04
Filter RM 217.62
Filter Element RM 47.09
Replace Alternator Belt RM 11.00
Fan Belt RM 195.30
Replace Expansion Tank RM 55.00
Replace Rear Cyclinder Head Connector RM 110.00
Thermostant RM 170.00
Expansion Tank RM 324.62
Anti Freeze RM 57.28
Connector RM 44.97
Car Wash (FOC)
Total Labour RM 253.00
Total Parts RM 1068.25
Lubricant RM 168.00
Total RM 1489.25
Service Tax 5% RM 12.65
Gross Total RM 1501.90
I remember i did change both side of the lower arm and bush for my e46 for Rm1500. i think this is one of the best deal in town.???
The list of failing parts keep mounting. Last nite, one of my kidney grills dropped off. Good thing it was at my car park so I could pick up the part and went over to Stuttgart this morning for a quick fix where I met Energy. Like my earlier gripe on power window regulator, the kidney's metal exterior is held on to the car's body by 6 flimsy plastic clips. On one side, all 6 clips had broken off while the other side 4 out of 6 clips had broken. I've never had a frontal impacts b4 and can only guess it was due to parking outside in the hot sun on some occassions. Energy's E46 325i is a couple of months older but his kidneys were intact. Anyways, Azwan of Stuttgart was kind enough to source 2nd hand but in good order kidneys for me, so 2 sets came out to total RM120-00 which I think is reasonable considering the original is RM250 each!
I also had a diagnostic done on my airbag warning light which came on a few days ago. It was discovered that my belt tensioners were faulty. To replace, incl. labour would cost me almost RM1,000. I fainted...
I wonder if CKDs got so much more problems than CBU and why these parts are so flimsy for a BMW. Didn't know they're outsourcing the manufacture of these parts in Rep. of Congo or Bangladesh!
Juan, ......my Airbag warning light was also due to driver's side seat belt tensioner faulty .....RM580 for part cost & RM60 labour (M-Speed) ... a year ago.
:( latest damage. Changed engine mounting. RM330 for a pair and RM80 for labour at M-Speed.
However, car seats do not have vibration feel now. One of those wear and tear items i suppose but now @ 60k kms?
Service Advisor: Stephen Bernard Albert
Date: 4/10/05
Oil Service (41783kms)
Shell Helix Ultra AB 6.5L - RM 377.00
(BMW Longlife Oil)
Oil Service Labour - RM44.00
Checking function of auto transmission - RM44.00
Programming control unit - RM66.00
Filt.Element - RM57.37
FILTER - RM217.62
CLEANER - RM11.04
Service Tax - RM7.70
Total - RM820.73
(I'm going elsewhere for Inspection II next year)
Handling is fantastic after changing the boomerang arms and bushes! Total cost:
1 set lower arms (lemforder) - RM1200
1 set bushes (lemforder) - RM500
1 bando 5PK950 belt - RM25
1 optibelt 6PK1705 - RM90
Labour - RM150
Total damage: RM1965
i performed inspection 2 in early sept at 72k mileage on my 1.9l, at optimum auto kayu ara biz park, pj.
spark plugs x 4 rm146.80
return line (p/steering hose leaking) rm 176
oil filter rm32.80
gasket (oil leaking out) rm22.30
o ring rm7.50
eng mounting x 2 (car vibrating badly at times) rm 372
air filter rm56.30
labour:
insp service rm60
renew eng mounting rm35
renew oil filter gasket rm65
renew p/steering hose rm15
oil:
shell helix ultra 4l rm168
syntheti atf (for p/steering reserve tank) rm18
grand total rm1217.20
