To do this correctly you will need
A manual
Engine wiring loom (manual)
Engine ecu programmed to a manual (I can help with the hw and sw numbers if needed)
Gear box
Selector complete
Sprig got bearing
Clutch kit
Clutch master and slave cylinders plus pipping
Prop shaft
Manual diff (if you want the correct ratios)
Clutch and manual brake Pedal
