E46 AIRBAG LIGHT ON
leakwoon
2 weeks b4...it was light onso the diagnos said the driver site tensioner belt initial circuit errorso the shop changed it for methen the light went offtomoro it went ON backthen the shop said normally the another sensor below the passenger seat of driverduno wat it is called la....need to be changedso changed alsoeverything happy for 1 week...yesteday... my friend adjusted the seatand the was an umberal underneath of it DARNNN the light ON againi heard this is very commong n repeating problem in e46..appreciate you guys advice!!thanks
If it came on from adjusting the seat its a quick fix usually, by a reset or tightening the connection to the sensor underneath it. Takes only a few mins to resolve.
The expensive one is the seat belt tensioner, which from the sound of it, you changed already....
I got the 2nd pwobwem now, the seat belt tensioner and haven't fixed it yet. I wonder where's the best place to do it and how much?
later i go back n try n error
else send back to shop
since they still give me warranty for last fix...
it was fixed this morning
disconnect everything
reset
start car
clear n reset
OKI liao
i stop n drive the car
2-3 times
restart engine
everything so far so good
JPB : seat belt tensioner is bout 5XX-6XX dependin on places u do. seat belt tensioner solved then yer pocket tension, heh :)
rgds, B)
kahar abdullah
they said when u change the belt tensioner
u gotta change another sensor together with it one also
duno how true is tat
TNS
sent my ride to CARS IXX wash n do the nanomist
now the airbag light is back
duno wat is the problem
need to go workshop again
Arrrghhh :(
they said sumtime the sensor "sensitive"
got such bullshit ar??
but abit off topic
the NANOMIST is cool man :D
:yahoo: :yahoo: i got mine fixed in M1 today...thanks to casey.
he checked my car and i only need to change the sensor due to tear and wear :cry: :cry: luckily it's because of the sensor and not the computer box,now everything done liao guys!!!!! :) :) on the other hand,the air bag problem it's because of the small little spring thingy dc from the dash board metal...i think it's the earth circuit.now everything DONE!!!!!RM 400++ for the sensor.. :cry: :cry:
good news bro
maybe i know wat is the error u got ?
the error log i got is driver side tensioner belt
Your topic has been towed to the appropriate section, in the future please refer to the main forum page for guidance.
There will be a link from the original place of posting leading to the new place (This states the approriate place).
If this thread is a tech question and if you are not sure which catergory to post under, please post under general tech.
If this thread is a 'FS or WTB' then post in the classifieds.
Thank You
-The Moderator
leakwoon & raymond,
my airbag indicator light has been going on & off the past 3 days....
Where did you guys get yours checked & repaired?
you can pm me if you want...
Thanks guys....
QD250;322787 said:
leakwoon & raymond,
Thanks guys....
My advise, get GT1 to diagnose, and make sure the voltage stabilizer securely connected (located in the rear trunk, there is a connector box just above the +ve battery terminal). Weak grounding could have caused the airbag to revert to safe-mode. For some reason it will register incorrect fault. Good Luck.
LazyServer
this problem happen to me too. This is because of my faulty Air Bag sensor under the passenger seat. Didn't change that yet. use GT1 to clear the error on that sensor but got error ...means the sensor totally gone...
my airbag sensor will come out everytime i send my car to cash wash, suspect after vacum it trigger the sensor, i jus bring to my mech to clear faulty code and prob solved, happend few time, its been quiet sometimes and i dont have the problem anymore
