E46, 2002, Aircond service
SSG kat Salak Selatan. Address dia ada di post #6 kat atas ni...
azeL_Inc said:
My aircond is making funny sounds right now, but so far it is still cold enough. Another thing that i found weird is that when i plug in my bmw scanner, it gives "HVAC motor faulty" error message. I suppose if the motor is faulty, my aircond wont work?
Sent from my Nexus 4
HVAC is a motor to regulate the temp and also to pump hot water to AC system when you switch to heater mode. Bro I have that motor bro for sale.
Bro, are you saying even HVAC motor faulty, the aircond still work (still cold)?
I thought if hvac faulty aircon also wont work. Haha.. But i do notice temp control is a bit out. Anyway pmed u alrdy.
Jarance,
I was told compressor for E46 to cond RM2.2K.....what type is RM1.2K?
Where is that place.....if new and all RM1.6K boleh la, This shop in Salak South charge RM1.1K for recond inc service. hmmmm
SBB said:
Jarance,
It was bought and installed at Naidu. Being using for a month now and it is damn cold.. LOL
Actually the marking is for E39 but can be used for E46. Maybe for E39 is cheaper..
Bro jakpo ada fon number tak SSG nyer kedai..valve controller tu means heater valve or idle valve bro???
Sorry lambat.... here is the details bro:
SSG Car Cooler
A20, Jln Tuanku 1, Salak South Garden
57100 Kuala Lumpur
Tel: 03-79805864
Mr. Chew Say Yew: 019-2402151
jarance said:
If make funny sound, it means that the compressor is about to kaput. maybe another 6 months usage.
If the compressor fail, better to get a new one rather than recon type. I have 2 recon compressor fitted and both
fail with 2 months usage. Finally change to new compressor at Naidu.
Sifu.. you may be bad luck on recon compressor changed ya ! Lol..
Fyi i did change mine since March 2012 at my friend workshop and it was just recently gv me problem.
Here was my post #1217: http://www.bmwclubmalaysia.com/newforums/index.php?/topic/56-e46-parts-maintenance/page-61
any good aircon sifu in ipoh coz my aircon compresor making sound dakdakdadk.not going to naidu coz in ipoh.pls tq
Ok I think my compressor finally gave in.. Haha..am scouting around for best deal for compressor changeout. Read that better change to new one. Any latest price update? Anyone has recently change compressor for N42?
Sent from my SM-N910C using Tapatalk
Update: Changed compressor, dryer, and electronic relay. Cost slightly above 2k.
ndsolo said:
For mine, it's as follows:
1) vacuum out oil and gas and refill oil - RM120
2) dryer - RM160
3) refill gas - RM60
Total RM340, no need to remove dashboard
Apologies Sifus, any place where can vacuum out oil from compressor and refill?
I think you should do it at Naidu as well. sent my car there for a/c job so many times before
you might want to check this ac evaporator as well
https://macsworldwide.wordpress.com/2010/07/12/the-evaporator-is-an-important-part-of-your-car%E2%80%99s-ac-system/
messy job
https://www.youtube.com/watch?v=N_LecuLoOhQ
it is inside the dashboard. 1 day job
