affan66
Founding Member
- Dec 5, 2004
- 4,455
Folks, I have this problem. Steering shimmy or wobbly at 80-120km/h. Yes. This is the famous E39 problem and I have had this for a few months already. Searched on the Net and here and had done the following: 1. Changed brake discs (front and back) and pads2. Off/On-wheel balancing and alignment (Batu Caves, Manji, Loke Yew shop) both front and rear tires3. Change rims!!!!! 4. Check for hub space - a few already said no need to put hubcentric cone5. Bearing - no problem6. Change front lower arm bush7. Adjust tyres around rim (positioning) Did not change tyres because they are new and don't have any bulges. I am using CSC3s. Based on research, there could be one more thing I need to do which is to change the thrust arms. These are still quite new (less than 2 years old) and show no signs of leaks or worn bushings. Any suggestions from the sifus here?
