E39 is coming...
Alhamdulillah malam tadi pegi jumpa bro yazmeen hehehe...
so lampu dpn dlm proses pembikinan yg baru...
check with scanner not much errors found so far so good...
reset the car IR remote update (2 button type)
locking with remote more smooth...
reset the IR remote to lock & unlock...
to lock the car just press the remote button once...
1) 1st press only the driver side door unlock...
2) 2nd press the others 3 door will unlock...
3) reset to auto lock when the car move after some speed it will autolock... ( dont have speed set up )
4) from inside driver can open door by pulling twice the door lever...(only driver side door for safety reason during filling up)
5) to open all doors at once just press the switch beside the gear lever...
than you so much bro yazmeen...
thats all at the moment hehehe...:rock:
Latest Up date hehehe...
The past have been taken over by the near future...
Old Headlamp right hand side...
New Headlamp left hand side...
New Angel Eyes left hand side...
New Angel eyes right hand side...
Right hand side New Angel eyes & Xenon low beam...
Left hand side New Angel eyes & Xenon low beam...
Both New headlamp Angel eyes & Xenon low beam...
So very the satisfied with the workmanship by non others then Bro Yazmeen...thumps up...:rock:
Next need to redo the fog lamp hehehe...:burnout:
nice upgrades bro.
i dont quite understand what u meant by new headlamps. yours was non angle eyes before?
huskar3399;821429 said:
nice upgrades bro.
Thanks bro huskar3399...
Actually mine is also with the angel eyes but amber color old fashion ( 1st & 2nd pics ) hehehe...
This is not a redo but totally change with another headlamp...
My old headlamp the lens cannot be open so have to change with a new headlamp...
- new angel eyes
- new reflector
- new Xenon hid with ballast
- new adjuster
- polish lens
Actually mine is also with the angel eyes but yellowish color old fashion ( 1st & 2nd pics ) hehehe...
- new angel eyes
- new reflector
- new Zenon hid with ballast
- new adjuster
- polish lens
why you want to open the headlight? to change the adjusters perhaps?
haywire;821483 said:
New adjuster and new white LED rings.
i understand the adjusters can be replaced without opening the headlight. and for the angle eyes, only the bulbs need to be changed with the LED, why need to replace the rings?
These are a ring of LED behind the existing light tube, not just changing the bulb. A lot brighter, you have to see it to know the difference.
Yes like bro haywire said need to change new adjuster and new LED rings...
Thanks bro...
There is alot of differance between this two angel eyes...
I think this is what bro haywire means...
Just now visit bro yazmeen again to replace the left hand side Xenon HID bulb due not functioning well...
Intermittent on / off so after replacing with new Xenon bulb the intermittent solved...
Thanks bro yazmeen...:top:
Nope, not that.
There's three different things here:
1. Original bulb - amber angel eyes
2. Changed bulb with white LED bulb - white colour angel eyes, not so bright
3. Put in a ring of LED behind current light ring - really bright white angel eyes.
Bro huskar is talking about 1 ---> 2, while what you did is 1 ---> 3.
haywire;821503 said:
Nope, not that.
Oh thanks for the explanation really appreciate it...I'm new to this kind of lightings...
Vixx..apa lagi tu, kasi racun lebih sikit !
Yup tweiboon your guess is right..and the car is in good hands now...
vixxx;821536 said:
Wohooo.....progressing nampak kehkehkeh
Nak racun ke... boleh... sekarang kat tangan i ada mtech 3 multifunction untuk E39, M5 interior door card + kerusi depan/belakang, msport door sill dan i ingat msport body moulding. ;)
Body moulding tak pasti belum buka check barang mungkin hari rabu akan angkat gambar upload.
Fuh menarik ni..........hehe
Thanks all for the racun in here hehehe...
Well may be not at the moment...
Coz 2moro wanna fix my cluster meter with bro haywire huhuhu...
Mine is already leather seat & memory so no need any mod at the moment happy with the interior set up...
For the steering well gona like it with the ori with the car hahaha...
Rim change already...
Headlamp also done...
2moro try to get the rubber button for my IR Remote from tweiboon...
Then if averything goes well will meet with bro haywire to refurbish my cluster meter hehehe...
The roof lining also need to do some make up....macam kelambu hahaha...:rock:
P/S What I like most with the new headlamp is...
During ignition key switch on before cranking it will do a cold scan by blinking right to left on both headlamp...
During day light not so noticeable but at night the blinking looks so nice...hehehe...
Latest update...
Replacing my IR Remote Button Rubber...
Bought the rubber from tweiboon this morning...
Back home DIY myself the IR Remote...
The old IR Remote with torn rubber button...
The new rubber button...
The IR Remote & the new rubber button...
The casing open remove the transponder & battery casing cover and new rubber button side by side...
IR Remote with new rubber button and the old rubber button beside...
IR Remote with the new rubber button fitted...
After DIY completed the IR Remote Key have to Initialized with the reciecver under the rear view mirror with some steps...
Initialising the transmitter I read in the Bimmerboard.com...
1)Open the driver side door with the key
2)Put the key into the ignition cylinder turn to position 1(on) for 5 seconds then turn off remove the key...
3)Press the no 1 button near key holder and hold then press the no 2 button near to key shell 3 times within 10 seconds...
4)Released button no 1 the LED will flash slowly for 10 seconds...
5)While the LED is flashing hold the IR Remote/Transmitter near to the reciever under the rear view mirror not more then 15cm then press any one of the buttons...
The central locking function will engaged and disengaged immediately indicating that the transmitter has been successfully initialised...
Any other transmitter use for the car (max 4 are possible) must be initialised with in 30 seconds and do not operate the ignition key...
If the LED do not flash or the central locking does not respond the initialising procedure must repeated...
Thanks to bro tweiboon for the rubber button...
Thanks to Bimmerboard.com...
