e38 battery short life span
uncle aziz
....I'm using DIN 100 maintenance free battery (brand name Atlas ). Ist battery lasted for 15 months and the second one using right now dead last few days lasted only 14 months.Is it normal ? Any suggestion for battery that can last longer. DIN 100 battery is expensive >>>Atlas rm450, Nova rm550.Hope admin /sifu can share the battery issue.
rezzsya;834091 said:
check your ignition coil.others is alternator.
.....all 6 coils and alternator are new , running only 7000 km since last date of installation. Current leakage checked negative.
Seldom drive at night . No accessories installed other than standard items provided by manufacturer.
unker... a true blue real maint free battery costs a bomb (circa rm 1k?) and will last at least 6 years.nowadays the so called maint free batteries are just what they are...free of maint ie no top up required but they will last just as long as normal lead acid battery ie 1.5 - 2 years...that is if you use the car regularly.if it's a garage queen.....well.....
yes its true....copper plate in new battery recycle product from old battery which had been corroded by acid>>>.afffect the quality of life. My proton saga and Matrix also having shorter life span of less than 2 yrs ...heavily used daily > 30 km.>80 km . ....keep a set of battery charger at home may be a good solution to keep max battery power.
new battery fixed....cap ayam brand No#a DIN100 rm400 net after less trade in rm30......more power with new battery.
Removed CD cartridge, aircon switch off>>>to check leakage.
3 days after new battery fixed, battery dead again.
Aduhhhhh....2nd time kena current leakage problem in 2 years.
Jump start again >>>let him sleep under Bayern garage for a week.
It's time to shift to smaller car>>1ser or z3
Unker better check your alternator if its not charging enough voltage...just my 2cents...
aku ada stereng lori dan bas......kau ada....
....sent to wshop yesterday for checking ....will take few days
Oh hope can solved it soon...
uncle aziz;835861 said:
....hope so, otherwise lelong sama dia......
So how unker...normally bat will last 1yr or 6mths but if quite fast something not right....
...tomorro to collect back e38 from w/shop. Accdg to my mechanic nothing wrong with the car. Since 19/7/13 thorough checking has been done/ not detect anyfaulty parts/system.
ada hantu ka itu kereta ?
