prabster;796784 said:Has anyone upgraded/replaced their BMW e38 2001 sound system speakers and still maintaining the original dashboard controls and steering wheel controls?
Prabha
prabster;808779 said:do you know the full specs for the e38 728i (2001) stock amp and wattage ratings? also my existing bmw 6 cd changer (alpine oem) seems to skip quite often. i read in one of the bmw UK sites how to take it out and open the casing and do some simple cleaning and adjustment and it will be fine..have not gone to do it..however i am looking to replace the ori bmw 6cd changer with an alpine changer and I read in one of the bmw forums..(cant remember which one) that you can get an interface adapter to connect any alpine cd changer (ibus system) to the e38 stock amp (different bus system) and still maintain the steering wheel audio controls. any ideas on this ??
prabster;808781 said:I cant seem to find Kaniz to PM...pls help.
anaksarawak;808970 said:Refer to alantiong the followings are my proposed speakers replacement for your car from Rockford Fosgate
SUBWOOFERBOX
The Pro PPS4-6 is a 6.50” 4-Ohm midrange loudspeaker engineered specifically for high SPL (Sound Pressure Level) conditions. It features 100 watt RMS power handing and includes grilles with mounting hardware.
The R152-S is a 5.25” 2-way component system rated at 40 watts RMS for a new generation of factory replacement speakers. Kit includes two woofers with grilles, two tweeters with integrated crossovers and mounting hardware.
The T252-S is a 5.25” 2-way component system featuring 1” aluminum dome tweeters and is rated at 75 Watts RMS. Kit includes pair or woofers with grilles, two tweeters with dedicated audiophile crossovers and mounting hardware.
sewell;809029 said:bro, where you get your rockford setup? i might want to upgrade mine current ori to rockford as well. is a smp need if we do this upgrade from ori?
anaksarawak;809036 said:I got my speakers from autocraft but installation was done at a old shop at Stapak. Nakamichi are not too bad either and its half the price of rockford
sewell;809050 said:bro, you got it from autocraft on USJ1 ?
alantiong;808960 said:Prab, i am running dice system. Took out thr changer and plonked in the ipod system. All function on steering and display otof ipod details on dash. Much better sound quality thank stock.
If your 38 comes with factory ice with amp... Then it will be pain in the butt to find bette speakers. I would suggest maintain all ori speakers and upgrade a sub. The ori speakers 5.25" are woofes and not mid. the mid and tweet are to small ones on top. Cannot find anything else to top them. The amp out put are filtered and will be pain to cross.
If u have 728i then no such issue lah...
More than happy to show u some pics of my car and the ipod docking
fender63lp68;810142 said:Alan,
Really interested in your ipod system. Care to share how to go about to do this.
I share with you that the stock system on the 728i is very decent. I have heard quite a bit elsewhere and I do find the SQ on the stock 728i is very very acceptable. Perhaps it just need to add a sub that can compliment the whole system.
BTW my stock amp have this problem that sometime it can switch off and on for no apparent reason. Do you know anyone who can fix the stock amp..?
