Hope Alfa Club member not reading this... sure kena laugh at..
Eddiedee.. life is fragile bro, HPC is more fun.
Are you sure it is not an Alfa 156 GTA?? Like many BMW's owners who has upgraded their engine to M3 or add turbo or supercharger
here the
engine 60 Degree, All Alloy, V6
position Front Tansverse
valvetrain DOHC, 4 Valves per Cyl
displacement 3179 cc / 194.0 cu in
bore 93 mm / 3.66 in
stroke 78 mm / 3.07 in
compression 10.5:1
power 186.4 kw / 250 bhp @ 6200 rpm
hp per litre 78.64 bhp per litre
bhp/weight 177.3 bhp per tonne
torque 300 nm / 221.3 ft lbs @ 4800 rpm
drive wheels FWD
body / frame Unit Steel
front brakes Brembro Vented Discs w/ABS, EBD, ASR, 4-Pot Calipers, Vacuum Ass
f brake size 305 mm / 12.0 in
rear brakes Brembro Vented Discs w/ABS, EBD, ASR, Vacuum Assist
r brake size 276 mm / 10.9 in
front wheels F 43.2 x 19.0 cm / 17.0 x 7.5 in
rear wheels R 43.2 x 19.0 cm / 17.0 x 7.5 in
front tire size 225/45ZR17
rear tire size 225/45ZR17
steering Rack & Pinion w/Power Assist
f suspension Double Wishbones w/Doubel Trailing Arms, Anti-Roll Bar, Telescop
r suspension MacPherson Struts w, Transverse Levers, Offset Coil Springs, Ant
weight 1410 kg / 3109 lbs
transmission 6-Speed Manual or Paddle Shift Sequential
gear ratios 3.500:1, 2.235:1, 1.520:1, 1.156:1, 0.971:1, 0.816:1
final drive 3.733:1
top speed 249.4 kph / 155.0 mph
0 - 60 mph 6.3 seconds
