e36 328 over heating
mahadzir2
dear friends,help me.....my car problem give me headache...always overheating even water in radiator is full...i just change water pump and fan...still over heating....and today water coming out from radiator cap....what to do.....please help methanks
where to find good mechenics in kuala lumpur.....i need to repair it...give me headache...thanks
Dude,
It is impossible to own a BMW and not eventually be best friends with a workshop. If you don't know one, you'll find it tough going.
For a car this age and this model, overheating becomes common as the cooling system gets old. I replaced mine entirely just last year.
If you use the search function, you'll find lots of threads discussing workshops to go to and which ones to avoid.
i know one workshop...mechanic claim i need to do overhaul...have to change cylinder head and gasket....claim for RM4K....still searching for good mechanic can give good rate...
Does your water level keep going down? How often do you need to top up the coolant? That is usually a clue. The check coolant warning message will come on.
me also headache for 2 months for overheat problem. finally its just a fuse. but dont change with cheap fuse, the plastic cannot stand the heat. get the good one from BA just RM2 each.
what fuse are you talking about? where is the fuse located? tq
mahadzir2;602148 said:
dear friends,
thanks
cooling system is really a headache...but be calm..check your radiator whether choking or not..check thermostat..check water pump..check hose both upper and lower..check expansion tank..check bleeding point when topping up the tank..kalau semua ok..pergi bawak ke workshop minta dia buat pressure test..than check lube oil colour..kalau sudah ada discoloration sign of engine effected..then maybe top gasket...kaput..slight warping..kalau asap sudah putih..seriuos bro..
