Apiz
- Jan 15, 2011
- 1,699
yat325;717326 said:kesian .....no reply at all hehehehehe.....piz bring it to the pro....as u mation b4 with me u pasang sendiri that part right, maybe ada yg slag bout the wiring bro...that part not cheep right...bole beku wooo heheheheh
ICEMAN 13;717328 said:i've changed the resistor too a long time ago when i had the no 2 , 3 and 4 which stop blowing air ...i think there is also some sort of aluminium comb there which needs to be replaced together with this resistor .. for worse case you may need to change your manual display gauge ...
firdaus325;717495 said:i think so.. aluminium comb. mcm jarum kt situ, try le cari half cut.
Apiz;717450 said:is it this thing
ICEMAN 13;717591 said:yes that's the thing that i replace ...if this doesn't work then your manual display gauge is gone ...need to replace that whole unit ...
Anthony5785;717932 said:You eat less satay and more vege, then you no need aircond...Sabar...Tell me if you want me to find for you in SG.....commission 6 Roti Canai + Teh Tarik...only (nego)
initialM;726446 said:I think its time to change car to F30
