E34 m50 engine TDC and Locking tools is important?
maxion89
bro... be carefull.. its important to lock/TDC.. and you may need special tools there.
figure 4 is the flywheel locking tool to prevent the bottom end from moving around. you can make out any std hand tools for that purpose. figure 35 is the procedure for TDC, camshaft and tensioner chain setup.
What do you want to DIY?
im doing a top overhaul here...
yea the tools is expensive so im doing without tools here if can. But i already look for research and there ppl can do it without tools...
